Mesh-71 Posted June 18, 2009 Report Share Posted June 18, 2009 I need a vacuum advance for an l16, mine is shot...It would need to be the style held on with two screws, Or if some body has one I could just use a matchbox dizzy if you have one with the pedestal. Saw lots of matchbox dizzy's at Canby but none of them had the pedestal. I would love to find one in the Portland area, I really don't want to have to ship something if I don't have to Let me know what you have Thanks Mark Link to comment
izzo Posted June 18, 2009 Report Share Posted June 18, 2009 man i gave away a stock distributor at canby, worked too. single point, complete Link to comment
bonvo Posted June 18, 2009 Report Share Posted June 18, 2009 i may have an extra vacume advance diaphram but its only held in with one screw :( 1 Link to comment
Skib Posted June 18, 2009 Report Share Posted June 18, 2009 I have a few dizzys layin around, ill see whats on em Link to comment
Mesh-71 Posted June 18, 2009 Author Report Share Posted June 18, 2009 Thanks for checking guys :) Link to comment
datzenmike Posted June 19, 2009 Report Share Posted June 19, 2009 ... if some body has one I could just use a matchbox dizzy if you have one with the pedestal. Saw lots of matchbox dizzy's at Canby but none of them had the pedestal. Thanks Mark Dude I believe (pretty sure) that your L16 pedestal will work. Just pop in the EI dizzy and go. Any L 4 or 6 cyl should work. Link to comment
Mesh-71 Posted June 19, 2009 Author Report Share Posted June 19, 2009 the matchbox is pretty much listed as a 79/80 L 20b and you want the mount that goes with it. I say again you want the mount that goes with it. This is quoted from one of the EI swap threads that I found, I also read a couple other times some thing about needing the correct pedestal...So that is what I was going by, if I can use the pedestal that is currently on my dime great, That much easier to find what I need. Link to comment
datzenmike Posted June 19, 2009 Report Share Posted June 19, 2009 If Hainz says so ..... IT IS!! (I wasn't totally sure) Any pedestal from '78 up with L 4 or 6 cyl will work then. Link to comment
yello620 Posted June 20, 2009 Report Share Posted June 20, 2009 I have a spare EI dizzy with the pedastal, Also comes with a coil. I am asking $60 OBO OBO You are listed as Oregon city, and i might be headed that direction this evening. Let me know if you are interested.. Link to comment
DISLEXICDIME Posted June 20, 2009 Report Share Posted June 20, 2009 i thought all the l series pedestals worked but the z series didn't Link to comment
yello620 Posted June 20, 2009 Report Share Posted June 20, 2009 The dizzy will fit into any L pedastal, but getting a adjuster plate between the pedastal and dizzy that allows correct adjustment is the problem. So getting a EI with the pedastal Works best for most peoples conversions. Link to comment
