Flared4door Posted June 15, 2009 Report Share Posted June 15, 2009 (edited) So i have an l16 with a dog leg 5 speed and for some resone it doesnt like to shift into gears. It have an exedy stage 2 newclutch and has been fully bled like 4 times the past week to try and fix it. Please help!! Edited June 15, 2009 by datzenmike Quote Link to comment
banzai510(hainz) Posted June 15, 2009 Report Share Posted June 15, 2009 Go under and see how much movement is at the slave. Then ask yourself? maybe the fork arm is bent? maybe need new clutch master? is it leaky or if you oush the pedal does airbubbles come up inside the resivor.If yes then master is bad. Quote Link to comment
datzenmike Posted June 15, 2009 Report Share Posted June 15, 2009 Check the oil level. The filler bung is about half way up the side of the tranny. You should have the oil up level with the opening and be able to touch it with your finger tip. Do this before you drive it again. Quote Link to comment
datto510 Posted June 15, 2009 Report Share Posted June 15, 2009 Then ask yourself? maybe need new clutch master? is it leaky or if you oush the pedal does airbubbles come up inside the resivor.If yes then master is bad. How you know that Hainz?:D Quote Link to comment
banzai510(hainz) Posted June 15, 2009 Report Share Posted June 15, 2009 How ??????Cause your a PIMP and I had a spare ready to go it. Cause you saw the air bubbles!!!!!!!!!!!!! Quote Link to comment
Flared4door Posted June 15, 2009 Author Report Share Posted June 15, 2009 thanks haniz....And word on the street is you painted the pink sun red again Quote Link to comment
