1fatsz Posted June 14, 2009 Report Share Posted June 14, 2009 (edited) Selling my ride https://accounts.craigslist.org/post/shwpst?pii=1213770000&db=lv Edited June 14, 2009 by 1fatsz Quote Link to comment
fastdadd Posted June 14, 2009 Report Share Posted June 14, 2009 you have to have a craigslist account to see your link Quote Link to comment
1fatsz Posted June 19, 2009 Author Report Share Posted June 19, 2009 (edited) you have to have a craigslist account to see your linkwhoops thanks for letting me know. Here is the correct Link. http://losangeles.craigslist.org/lgb/cto/1229543830.html OK..I think the time has come to sell my SE-R ...This car is in great mechanical condition.....reason for selling is i cant have two toys..since i have a s30 now all my time and money is going into that... so my b13 needs a new home and one that will appreciate it. It isn't all perfect as it has been banged up in some places so the paint needs a touch up..but it is only cosmetic damage...there is no actual body or structural damage...the interior is pretty good but could be better.. Engine Currently has about 20k on it since i have swapped the engine to a silver top avenir engine... it still has the t25 that has little to no shaft play...and has JWT S4 cams..The tranny has been swapped out to a 99 g20t tranny that had 35k on it about 10k ago...also has a new 6 puck clutch with a fidanza 10 pound flywheel and redline gear oil.. The car has D2 coilovers with about 10k on them since i installed them..it has all new wheel bearings and axles...the brakes are stockers with cross drilled rotors... Goodridge steel braided lines and racing blue brake fluid...this setup works real well but isn't the best. Here is a list of the mods: Avenir SR20DET 60k miles... walbro 255 fuel pump Nismo FPR... JWT S4 Cams JWT ECU.. JWT Poly Motor Mounts Redline Gear Oil Royal Purple oil every oil change at every 3k miles Griffin 2 row aluminum radiator PS Short Shifter Custom 3" Mandral Bent Turbo Back Piping.. Goodridge steel braided brake lines .. D2 Coilovers 32 point adjustable suspension Stewart warner gauges Hotshot front mount piping kit Presicion Front mount intercooler bar and plate.. HKS BOV.. New SSK Bronze rims and Falken tires less than 2k miles New trunk mounted optima Battery 99 G20 tranny 40k miles Fidanza Flywheel 6 puck clutch kit good for 350hp SCAT Bucket seat with slider 6k HIDs tsuru headlights plus some other things i cant think of at the moment.. $5000 Car was dirty in these photos Edited June 19, 2009 by 1fatsz Quote Link to comment
