Dust Posted June 14, 2009 Report Share Posted June 14, 2009 They make B/A front coilovers for a 510.. I hear most 510 parts fit a 610 Do you guys think their coilovers will fit on a 610? Need answer soon! Thanks everyone! Quote Link to comment
INDY510 Posted June 14, 2009 Report Share Posted June 14, 2009 No... definatley NO,,,, I think BEEBANI is selling brackets for 620 coilovers,,, they are totally different than 510 coilovers. Quote Link to comment
kiznook Posted June 15, 2009 Report Share Posted June 15, 2009 What are B/A coilovers? yes they will fit a 610, but not a 620, like indy was talking about, but he can't read Quote Link to comment
zerow Posted June 15, 2009 Report Share Posted June 15, 2009 Are you running stock struts? If so, I can be of no help. I suggest upgrading the front brakes to the 280ZX setup. Then you can use any coilover that has a 2 inch inner diameter. The solid rotors on the 610 are prone to warping from heat and infamous for brake fade with prolonged use. The vented rotors with the 280ZX allow for better braking that will be around longer than stock 610 brakes. Quote Link to comment
Dust Posted June 15, 2009 Author Report Share Posted June 15, 2009 hahaha yeah man i ment for a 610. B/A means bad ass coilovers. So you sure they will bolt right up to the 610 even if they are for 510? Quote Link to comment
INDY510 Posted June 15, 2009 Report Share Posted June 15, 2009 I hear most 510 parts fit a 620Do you guys think their coilovers will fit on a 620? That's what I read:blink: Damm I need some glasses.......:blink: You need to weld a perch for the coilovers to fit on: I shortened my strut tubes and re-threaded the tops, You don't need to do this to run coilovers,, I just wanted my car really low.. This is for a 510 with stock struts,,,, Are you planning to run camber plates??? Can you weld? What kind of shock inserts do you want??? It gets expensive.... Quote Link to comment
Dust Posted June 15, 2009 Author Report Share Posted June 15, 2009 indy if you didnt know the t3 coilovers can go to a max of around 10" of droppness, they are real coilovers, not coilover "sleeves". Looks like to me in the picture it should all bolt up according to plan. Quote Link to comment
69FJWagon Posted June 25, 2009 Report Share Posted June 25, 2009 are you talking front or rear? Quote Link to comment
