5casey1dimer0 Posted June 14, 2009 Report Share Posted June 14, 2009 Hello all, a while since i've been on, busy with school and work. Anywho, ever since i've gotten my 510 the windows and windshield especially have been pretty foggy/hazy/cloudy, whatever you want to call it. I've never bothered tryin to clear them up since its not my daily, I'm sure you guys know a trick to fixin' up those old windows, what is it? Thanks in advance, -casey- Quote Link to comment
datzenmike Posted June 14, 2009 Report Share Posted June 14, 2009 The safety glass windshield is a thin plastic layer sandwiched between two sheets of glass. The plastic may have deteriorated from age and is becoming opaque. No cure for this but replacement. On the other hand, if it's just a build up of pollen dust and mildew dried on it you can scrub it off with steel wool, give a good cleaning and good to go. Quote Link to comment
motavated Posted June 14, 2009 Report Share Posted June 14, 2009 Very fine wool like 0000 Quote Link to comment
5casey1dimer0 Posted June 14, 2009 Author Report Share Posted June 14, 2009 The safety glass windshield is a thin plastic layer sandwiched between two sheets of glass. The plastic may have deteriorated from age and is becoming opaque. No cure for this but replacement. On the other hand, if it's just a build up of pollen dust and mildew dried on it you can scrub it off with steel wool, give a good cleaning and good to go. Thanks mike, ill give it a shot:thumbup: im afraid its probabaly that plastic layer though. Quote Link to comment
datzenmike Posted June 14, 2009 Report Share Posted June 14, 2009 Glass is tougher/stronger than steel so it won't scratch. Good on chrome bumpers too. Quote Link to comment
Moisabamf Posted June 14, 2009 Report Share Posted June 14, 2009 Hello all, a while since i've been on, busy with school and work. Anywho, ever since i've gotten my 510 the windows and windshield especially have been pretty foggy/hazy/cloudy, whatever you want to call it. I've never bothered tryin to clear them up since its not my daily, I'm sure you guys know a trick to fixin' up those old windows, what is it? Thanks in advance, -casey- here's mine:D: Quote Link to comment
5casey1dimer0 Posted June 14, 2009 Author Report Share Posted June 14, 2009 Is that sort of sarcastic as in "wash the damn window" or is there actually a method you have with soap? Quote Link to comment
MikeRL411 Posted June 14, 2009 Report Share Posted June 14, 2009 JC Whitney for years sold a Cerium Oxide glass buffing kit for windshields and side windows. With luck it's the surface crud and Cerium Oxide is gentler [is there such a word] than steel wool, even 0000 grade used for furniture restoration. If it's the center plastic, most states even those with inspection requirements will give you a pass. Quote Link to comment
5casey1dimer0 Posted June 14, 2009 Author Report Share Posted June 14, 2009 JC Whitney for years sold a Cerium Oxide glass buffing kit for windshields and side windows. With luck it's the surface crud and Cerium Oxide is gentler [is there such a word] than steel wool, even 0000 grade used for furniture restoration. If it's the center plastic, most states even those with inspection requirements will give you a pass. thanks! ill look into that, and im not worried about inspection requirements, there not that bad, just enough to bug me, sort of like drivin with a dirty windshield. Quote Link to comment
