lynchfourtwenty Posted June 12, 2009 Author Report Share Posted June 12, 2009 thats a good idea Quote Link to comment
mike Posted June 12, 2009 Report Share Posted June 12, 2009 If your U-joints are bad to the point of wobbling that bad replace them AS SOON AS FUCKING POSSIBLE. Id be worried about driving around the block. If they let loose they can rip your pinion apart, take out wiring, exhaust, fuel/brakelines... whatever. Figure youve got a 2 or 3 foot metal rod spinning around under your truck smacking the shit out of anything in its way... It would definately be cheaper and easier to just get a different used D-shaft with decent ujoints and then grease those ones up up. Hell, someone on here probably has one theyll give you seeing as how youve got the carrier bearing fixed (Im curious to see how that holds up, if it works you cant beat the price) If you do drive it still take her easy, no burnouts or crazy stuff. Quote Link to comment
lynchfourtwenty Posted June 12, 2009 Author Report Share Posted June 12, 2009 ok so i jus took it to oil can henrys which is literally right down the road, they greased her up an topped her off on oil for FREE!!!!! still vibrates, i think its u-joints.. well theres my next thread.. Quote Link to comment
Madness Posted June 12, 2009 Report Share Posted June 12, 2009 too bad about the u joints. Score on the free service :cool: Quote Link to comment
]2eDeYe Posted June 12, 2009 Report Share Posted June 12, 2009 the clank is heard when you accellerate an then let off quickly without puttin the clutch in.. And when reversing out of my driveway.. or parking spot.. its just 1 clank.. say i reverse a little then let off clutch in an brake clank then back on gas clank let off clank.. Textbook u-joint failure warning signs ;) Cheap to fix and fairly simply with the right tools. Datzenmike did a writeup :) Quote Link to comment
datzenmike Posted June 12, 2009 Report Share Posted June 12, 2009 http://forum.ratsun.net/showthread.php?t=2357 Quote Link to comment
lynchfourtwenty Posted June 12, 2009 Author Report Share Posted June 12, 2009 thanks i'll look it over after canby :) trucks not going this year :( Quote Link to comment
sssr20det510 Posted June 12, 2009 Report Share Posted June 12, 2009 bring it by my shop ill look at it for ya Quote Link to comment
lynchfourtwenty Posted June 12, 2009 Author Report Share Posted June 12, 2009 will do :) Quote Link to comment
Mesh-71 Posted June 12, 2009 Report Share Posted June 12, 2009 You are really only looking at a hour fix, I have seen guy out wheeling be able to change them out in 15 min. The vancouver autozone has them in stock, and they cost ten bucks, duralasts are not the best u joints, but it would get you to canby Quote Link to comment
datzenmike Posted June 12, 2009 Report Share Posted June 12, 2009 Fuckin' DO it! Quote Link to comment
F8d2blk1 Posted June 18, 2009 Report Share Posted June 18, 2009 I was wondering if you could put a poly bushing in there instead of rubber? Quote Link to comment
lynchfourtwenty Posted June 30, 2009 Author Report Share Posted June 30, 2009 so i re did my ratsun carrier bearing, it had come un done.. so what i did was added another rubber ring thing from a air filter i had layin around, was pretty thin an rubber.. then i re wrapped that with the other rubber stuff i was using.. slipped the ring on, then i used a little excess i had from that strip to fill in any gaps or loos spots, also i zip tied the rubbed on there, used 2 zip ties an pulled em as hard as i could.. so hopefully that fucker will stay in there, however.. she still vibrates like an old lady on a spin cycle with an off set load. so im gonna take the drive shaft down to premium automotive repair an have jeremy (sssr20det510) hook me up with some u-joints :) hopefully that solves the problem.. other wise id wtf ima do.. if that shit dont fix it, its in the tranny or clutch or something, an if thats the case the trucks gonna take a loooonnnnggggg nap until i can dig into her again.. which will suck.. so lets hope its the fuckin u joint.. Quote Link to comment
Madness Posted June 30, 2009 Report Share Posted June 30, 2009 after that i would say balance the tires....? Quote Link to comment
ariascarlos1990 Posted June 30, 2009 Report Share Posted June 30, 2009 you'll figure it out..:D Quote Link to comment
lynchfourtwenty Posted June 30, 2009 Author Report Share Posted June 30, 2009 after that i would say balance the tires....? honestly i doubt its the tires since its goes on an off with gas pedel lol Quote Link to comment
fastdadd Posted June 30, 2009 Report Share Posted June 30, 2009 i think it is u-joints....but i had a bent input shaft on a trans that drove me nuts trying to find Quote Link to comment
lynchfourtwenty Posted June 30, 2009 Author Report Share Posted June 30, 2009 ya i think its u joints too, i'll be fucking pissed if its the tranny.. if it is ima slap another damn 4 speed in Quote Link to comment
Skib Posted June 30, 2009 Report Share Posted June 30, 2009 if it is the trans Iv got one sittin around here Quote Link to comment
lynchfourtwenty Posted July 1, 2009 Author Report Share Posted July 1, 2009 gooooood :) Quote Link to comment
