qmrp2567 Posted June 1, 2009 Report Share Posted June 1, 2009 I'm looking for a Fuse box and harness assembly. I am doing a 510 swap. I need the fuse box with the wires up to the connetor. I have the engine wire harness. This is a 5 speed engine. Link to comment
philcas1987 Posted June 2, 2009 Report Share Posted June 2, 2009 Don't waste your time grafting a 240sx wiring harness. All you need is the engine harness. Painless makes nice relay bases, and small fuse blocks. If you go the other route you are still going to end up cutting,spilceing, and deleteing to make it look clean. There is a nice how to in the how to section. If you haven't already read through it. If not you should have no problem finding someone to take your money. Link to comment
