datsunfish Posted June 1, 2009 Report Share Posted June 1, 2009 I need whatever will work to convert my 510 to manual. Clutch and brake pedals as well as mounting hardware,hydraulic tubing and used master and slave cylinders if in good shape. I have my motor in and will be bolting it all together this week. Link to comment
slodat Posted June 1, 2009 Report Share Posted June 1, 2009 All you need are the two pedals. You don't have to remove the surrounding structure. Just bolt the manual transmission pedals into your car. Link to comment
AZhitman Posted June 1, 2009 Report Share Posted June 1, 2009 I have the full pedal assembly you need. PM me and we'll work something out. Link to comment
banzai510(hainz) Posted June 1, 2009 Report Share Posted June 1, 2009 Im sure Icehouse or Frank have these. PM them You need manual pedal assembly and the gas pedal from a maunual also as a automatic gaspedal is more striaght and will be too close to the gas pedal. Incase if a panic stp youll hit both brake and gaspedal. I assume you might have to short out the auto trans switch (or wiring on the car side)so it will start.?????????? Link to comment
fivetenzen Posted June 2, 2009 Report Share Posted June 2, 2009 I got a set sitting on my garage floor - 25.00 plus shipping from 95901 - Steve Link to comment
