HP11 Posted May 31, 2009 Report Share Posted May 31, 2009 J16, Weber 40DCOE, header, dual remote oil filters, 200SX dogleg 5 speed, 3.889 roadster rear end, rear sway bar, urethane bushings, 1995 Nissan Hardbody alloy wheels on custom made hub centric adapters, Hyundai bucket seats, Subaru center console, mahagony overhead console w/stereo, cd changer, much more. SOLD!! Link to comment
xlr8r Posted May 31, 2009 Report Share Posted May 31, 2009 Let me be the first to say that is a beauty. Link to comment
FNLO620 Posted May 31, 2009 Report Share Posted May 31, 2009 That is a clean ass truck, Good luck with the sale. Link to comment
jefe de jefes Posted May 31, 2009 Report Share Posted May 31, 2009 IMH? getting rid of her huh? Link to comment
Pacific coast Datsun Posted May 31, 2009 Report Share Posted May 31, 2009 Say it aint so Stephen...it's cheaper to keep her:D Link to comment
HP11 Posted May 31, 2009 Author Report Share Posted May 31, 2009 (edited) IMH? getting rid of her huh? Yep, that's me. (Irene's mother's husband) AKA 810-again, HP11, sblake01, blakes320, depending on the site. I've had the truck for almost 29 years, it's time for a change. Edited June 1, 2009 by HP11 Link to comment
mklotz70 Posted June 1, 2009 Report Share Posted June 1, 2009 those are the best pics I've ever seen of your rig! I like the taillights!!! Decided to go with something that has A/C??? :) I'm sure I'll sell mine before it ever gets that nice. Good luck!! Link to comment
HP11 Posted June 1, 2009 Author Report Share Posted June 1, 2009 Those taillights were done by a guy in La Puente, CA. years ago when things like that were still somewhat reasonable. They're actually made from a mid 70s Ford LTD taillight, cut in half and mounted behind the panel he made. I still think AC can be done in these trucks, I just never got around to it. Link to comment
mklotz70 Posted June 2, 2009 Report Share Posted June 2, 2009 I agree...I think it can be done too. I'd probably look for a smaller compressor off a newer compact car. I'll bet I sell mine before I get around to A/C too :) Link to comment
mklotz70 Posted June 4, 2009 Report Share Posted June 4, 2009 Congrats!!! Did you give him Ratsun's info? Is he brining it to Canby? :) j/k on the last one! Link to comment
HP11 Posted June 4, 2009 Author Report Share Posted June 4, 2009 Congrats!!! Did you give him Ratsun's info? Is he brining it to Canby? :) j/k on the last one!It has a Ratsun sticker on the back window. He spoke of putting it in the Datsun Heratige Museum for a while which is something I would like to have done also had I kept it. Link to comment
fisch Posted January 2, 2010 Report Share Posted January 2, 2010 It has a Ratsun sticker on the back window. He spoke of putting it in the Datsun Heratige Museum for a while which is something I would like to have done also had I kept it. Hey Steve, I know you sold this awesome rig, but I was wondering if you could tell me more about the J16? (I am thinking of my 1959.) How did you find one in Japan? Is it 3 bearing or 5 bearing? What did they come out of? Did the 200sx dogleg bolt right to it? If you hadn't gone to floor-shift, would the sidedraft have hit the column shift linkage? I assume you had to get a new driveshaft made? I'd really appreciate any info you have on it! Link to comment
HP11 Posted January 3, 2010 Author Report Share Posted January 3, 2010 Hey Steve, I know you sold this awesome rig, but I was wondering if you could tell me more about the J16? (I am thinking of my 1959.) How did you find one in Japan? Is it 3 bearing or 5 bearing? What did they come out of? Did the 200sx dogleg bolt right to it? If you hadn't gone to floor-shift, would the sidedraft have hit the column shift linkage? I assume you had to get a new driveshaft made? I'd really appreciate any info you have on it! I bought it from one of the many importers that were around in 1997. The name of the company is C&T International, Inc., located in Pico Rivera, CA. They're still around but they can't get the J16 anymore. I don't know where you find one nowdays. It's a 5 main bearing engine. I came from a Homer T20 which was a Datsun truck not imported to the US. The 200SX dogleg bolted to it because of the mouning plate that came with it. (Sheer luck!!) It wouldn't have fit the column shift trans without using the mounting plate that goes with the coulmn shift trans as well as the clutch, flywheel, etc. that goes with the column shift trans. I don't know about clearance with the sidedraft/column shift linkage since I never tried that. I had to get a new drive shaft made because of the dogleg trans and the SPL311 differential (3.889) as both yokes were different from the 320. I also had to do some trans mount modification but I don't recall what I did there as it was 12 years ago when I did the swap. Link to comment
fisch Posted January 3, 2010 Report Share Posted January 3, 2010 I bought it from one of the many importers that were around in 1997. The name of the company is C&T International, Inc., located in Pico Rivera, CA. They're still around but they can't get the J16 anymore. I don't know where you find one nowdays. It's a 5 main bearing engine. I came from a Homer T20 which was a Datsun truck not imported to the US. The 200SX dogleg bolted to it because of the mouning plate that came with it. (Sheer luck!!) It wouldn't have fit the column shift trans without using the mounting plate that goes with the coulmn shift trans as well as the clutch, flywheel, etc. that goes with the column shift trans. I don't know about clearance with the sidedraft/column shift linkage since I never tried that. I had to get a new drive shaft made because of the dogleg trans and the SPL311 differential (3.889) as both yokes were different from the 320. I also had to do some trans mount modification but I don't recall what I did there as it was 12 years ago when I did the swap. Super info! Thanks so much! Nice to hear they were 5 main engines. I would think if one could find one, it would be a good candidate for a moss supercharger MGB kit. It also makes me hopeful that the legendary J18 from a mexican 200sx Sakura would be 5 main too! Link to comment
