Good looking L series engines (pic request)
  • Replies 151
So Little L6 Love....
Here's Derek's Hand Built/Custom ITB setup. If you've got enough money waiting to burn a hole in your pocket, a set can be yours (I'm pretty sure it's safe to say that excludes us?)
Oh, and here's what an L28 looks like with a twin cam head bolted on...
Mine is far more "industry standard" than anything exceptional...
I did score this 32/36 DGV Weber for 30 bucks today though! :rolleyes: It looks right at home...until it gets evicted by a set of 4 motorcycle carbs :D
i like the 'plugged' coolant bypass.
second race motor ive seen this month with it. ;)
Might I ask what you valve breather set-up is? I haven't seen one like that before. Does it push the oil/vapor back into the crankcase via the pressure/temp sender hole in the block?
he can confirm, but i think what you see is the cam oiler spray bar (additional hardware on the cover)
