spottedog Posted May 23, 2009 Report Share Posted May 23, 2009 What would be the correct motor mounts to use on a Z24 block in a 1980 720 pickup that originally had a L20-B engine in it? :confused: This is a 4 wheel drive if it makes a difference. Quote Link to comment
sdsurf Posted May 23, 2009 Report Share Posted May 23, 2009 i have some if you are looking Quote Link to comment
spottedog Posted May 24, 2009 Author Report Share Posted May 24, 2009 i have some if you are looking What kind are they? I used the stock mounts that were on the old L20B but they were a bitch to get on and sit at a odd angle when mounted to the Z24 block. Quote Link to comment
hang_510 Posted May 26, 2009 Report Share Posted May 26, 2009 the stock NISSAN mounts should be fine. ive found the aftermarket mounts to be ~1/2" thicker. it was still a bitch to bolt it in (the 510) Quote Link to comment
datzenmike Posted May 26, 2009 Report Share Posted May 26, 2009 (edited) What would be the correct motor mounts to use on a Z24 block in a 1980 720 pickup that originally had a L20-B engine in it? :confused: This is a 4 wheel drive if it makes a difference. First, use Z24 motor mounts to position the motor. You will also need a Z series transmission in order to use the Z24 engine. Second, all 4X4 oil pans are offset to the side to clear the R-180 front differential. All Z motor equipped 4X4s had the differential offset to the driver's side of center line, and the oil pan is deepened and offset to the right side for clearance. The '80 4X4 had the distinction of having the differential offset to the passenger side and the L20B oil pan offset to the left for clearance. So, a Z24 oil pan, 2 or 4wd, will not clear the the '80 4X4 differential position. What I would do is install the L20B 4X4 oil pan and pick-up on the Z-24 motor. Because of the 12 degree tilt difference between the two motors the pan won't sit quite level BUT it should clear the differential. Here is my L20B oil pan for '80 4X4. This is the position it should sit in IF it was bolted to an L20B motor. When bolted to a Z motor the top where the gasket would be will sit more level and the bottom part will be tilted. The bottom reservoir could also be dinged with a hammer if needed. http://i138.photobucket.com/albums/q251/datzenmike/720%20stuff/720stuffL20Boilpan4X4001Large.jpg[/img]"] Edited May 26, 2009 by datzenmike Quote Link to comment
spottedog Posted May 27, 2009 Author Report Share Posted May 27, 2009 (edited) First, use Z24 motor mounts to position the motor. You will also need a Z series transmission in order to use the Z24 engine. Second, all 4X4 oil pans are offset to the side to clear the R-180 front differential. All Z motor equipped 4X4s had the differential offset to the driver's side of center line, and the oil pan is deepened and offset to the right side for clearance. The '80 4X4 had the distinction of having the differential offset to the passenger side and the L20B oil pan offset to the left for clearance. So, a Z24 oil pan, 2 or 4wd, will not clear the the '80 4X4 differential position. What I would do is install the L20B 4X4 oil pan and pick-up on the Z-24 motor. Because of the 12 degree tilt difference between the two motors the pan won't sit quite level BUT it should clear the differential. Here is my L20B oil pan for '80 4X4. This is the position it should sit in IF it was bolted to an L20B motor. When bolted to a Z motor the top where the gasket would be will sit more level and the bottom part will be tilted. The bottom reservoir could also be dinged with a hammer if needed. http://i138.photobucket.com/albums/q251/datzenmike/720%20stuff/720stuffL20Boilpan4X4001Large.jpg[/img]"] So I would order Z24 mounts to replace the L20B mounts that need replacing? Are there Z24 "4WD mounts" or are they all the same? The pan and transmission clocked position are in order. Edited May 27, 2009 by spottedog Quote Link to comment
datzenmike Posted May 27, 2009 Report Share Posted May 27, 2009 The rubber 'sandwich' (motor mount) for the L20B might work for the Z motor. There are a left and right bracket that bolt to the rubber and also to the Z engine block to position it properly. These will be much different to the L series ones. Z24 side brackets and rubber mounts are the same for 2 and 4 wd. This is not true of other 720 motors. Quote Link to comment
hang_510 Posted May 27, 2009 Report Share Posted May 27, 2009 The rubber 'sandwich' (motor mount) for the L20B might work for the Z motor. There are a left and right bracket that bolt to the rubber and also to the Z engine block to position it properly. These will be much different to the L series ones. if the L brackets are used on the Z block(which they are in my case) does that affect/correct the angle (of the dangle)? maybe thats why its a :cursing: to install??? Quote Link to comment
datzenmike Posted May 27, 2009 Report Share Posted May 27, 2009 if the L brackets are used on the Z block(which they are in my case) does that affect/correct the angle (of the dangle)?maybe thats why its a :cursing: to install??? .... yes. Quote Link to comment
Jda222221 Posted June 22, 2020 Report Share Posted June 22, 2020 Does the 12 degree tilt difference apply to a z22 swap into z24 body? https://ibb.co/d25jhRR https://ibb.co/FxhLT6R Those the the pics Quote Link to comment
