RiverRat Posted May 22, 2009 Report Share Posted May 22, 2009 Hello, I like my 521 so well that I am thinking of buying a Frontier with a 6-speed transmission. I cant find any info. on the 6-speed as far as gear ratios. Does anyone have any expierence with the 6-speed? thanks Quote Link to comment
sssr20det510 Posted May 22, 2009 Report Share Posted May 22, 2009 1st = 4.37 2nd = 2.52 3rd = 1.74 4th = 1.28 5th = 1.00 6th = 0.77 Quote Link to comment
72240z Posted May 22, 2009 Report Share Posted May 22, 2009 That's a high and to me pointless 6th. There are t5s with lower 5ths lol. Quote Link to comment
Bleach Posted May 22, 2009 Report Share Posted May 22, 2009 yup, the gears are closer together and you have more of them. Likewise, you would generally run a taller rear gear and larger tires. Quote Link to comment
LCDC Posted May 22, 2009 Report Share Posted May 22, 2009 I'd just put the 521 on the frontier and call it good. Quote Link to comment
Icehouse Posted May 22, 2009 Report Share Posted May 22, 2009 Wait, wait.... Is the 6 speed bolted to a KA? Quote Link to comment
72240z Posted May 22, 2009 Report Share Posted May 22, 2009 I'd assume vq40de. There is no bolt on 6 speed that I know of for the ka. Quote Link to comment
datzenmike Posted May 22, 2009 Report Share Posted May 22, 2009 Drool.... pant, pant.... 'cause if it fit the KA.... it would fit the Z24! :D Quote Link to comment
Icehouse Posted May 22, 2009 Report Share Posted May 22, 2009 You assholes!!! Getting me all excited about a non existent tranny....:blink::eek::fu: Quote Link to comment
72240z Posted May 23, 2009 Report Share Posted May 23, 2009 Well the trusty tremec t56 have been adapted to sooooo many engines already. It's what I plan to use for my L series. Could always jump on that band wagon :-). I bet there is a bolt on solution too, I found one for the L and don't the K and L fit just off axis a bit? Quote Link to comment
sssr20det510 Posted May 23, 2009 Report Share Posted May 23, 2009 You assholes!!! Getting me all excited about a non existent tranny....:blink::eek::fu: Cant you use the s15 tranny and just change the bellhousing or this one http://www.rhdjapan.com/jdm-low/NISMO-Silvia-180SX-Reinforced-Cross-6-Speed-Transmission-20977 Quote Link to comment
72240z Posted May 23, 2009 Report Share Posted May 23, 2009 (edited) The 6 speed uses a 3 piece housing where as the 5 speed uses a 2 piece. Beyond that the newer sr's from the s15, 180sx yada yada have a different bolt pattern. It not bolting up isn't the only issue, the silvia 6 speed is notoriously weak. If that wasn't the case I imagine they would be selling adapters like hot cakes, just like they sell every other bolt on off the shelf mod under the sun. Edited May 23, 2009 by 72240z Quote Link to comment
