distributor upgrade
maximo
I got my hands on a 79 matchbox dizzy and coil and I want to put it on my l20b engine but I don't have the wiring. I looked for instructions on how to hook it up but I could not find any. My 620 is a 74 with the old style points distributor.
  • Replies 6
On the '74... find the Black/White and the Black/ Red wires coming to the coil from the harness. Join them together and connect to the + side of the EI coil. Run a connection from the + coil terminal to the B terminal of the matchbox module terminal. Now run a connection from the - coil terminal to the C terminal of the matchbox module. That should give you spark in the crank and run ignition positions.
