DAW Posted May 18, 2009 Report Share Posted May 18, 2009 This manifold is in great shape and welding all looks good. http://i205.photobucket.com/albums/bb237/DAW_cars/DSCN05890001.jpg http://i205.photobucket.com/albums/bb237/DAW_cars/DSCN05870001.jpg http://i205.photobucket.com/albums/bb237/DAW_cars/DSCN059200011.jpg http://i205.photobucket.com/albums/bb237/DAW_cars/DSCN05900001.jpg DAW Link to comment
67411sss Posted May 20, 2009 Report Share Posted May 20, 2009 I think it is for the R series. Link to comment
MikeRL411 Posted May 20, 2009 Report Share Posted May 20, 2009 I think it is for the R series. It is for the RL411 type R 1600 cc engine, however it is missing the adapter section that goes from a two port to a single port for the actual exhaust tubing. The adapter has a heavy ring around the single hole which mates with the flared end of the tube to the front exhaust resonator [pre muffler] under the 411. The gasket between this manifold and the adapter section has long bee not available, however 2 510 exhaust gaskets can be cut so that they fit very well. The stud is for a brace to the engine block which bears the weight of the manifold. If missing, which is the usual case, the brace is easily fabricated from a piece of tubing or conduit with a few blows of a hammer and 2 holes drilled to match this stud and the tapped hole in the engine block. Link to comment
DAW Posted May 21, 2009 Author Report Share Posted May 21, 2009 Thanks for filling in the details. DAW Link to comment
ieshouston Posted October 9, 2011 Report Share Posted October 9, 2011 I'm interested in this manifold. Do you still have it? Link to comment
