dat u racing Posted May 17, 2009 Report Share Posted May 17, 2009 I'm running a z-bell behind frankinstien with stock Z-24 flywheel and clutch,has very short pedal should i install z thro out bearing ? if so what year Z car, also running non dg tranny 5speed. Quote Link to comment
datzenmike Posted May 18, 2009 Report Share Posted May 18, 2009 Be sure there is no air in the hydraulic system first. The bell or the tranny is irrelevant. The release bearing housing or sleeve is matched to the clutch and pressure plate diameter size. This is the diameter of the disc and/or the contact surface on the flywheel only. Measure yours to be sure. All Z24s used a 240mm clutch. The part number for it is 30510-K0401. (about $20) This is also the number for some of the 280 z/zx cars that also used this clutch size. Quote Link to comment
dat u racing Posted May 18, 2009 Author Report Share Posted May 18, 2009 ok thanks mike must b some air in there, i broke a tranny last knight so i this would of been good time to correct. sure am glad no one bitches bout spelling or typin. Quote Link to comment
boomstickracing Posted May 18, 2009 Report Share Posted May 18, 2009 use the bleeder on the slave cylinder first then the one on the master. did this a few years ago after changing my slave in a parking lot......LOL Quote Link to comment
datzenmike Posted May 18, 2009 Report Share Posted May 18, 2009 Is the master push rod adjusted so there is about 1/8" play before there is any resistance felt on the pedal??? Quote Link to comment
LCDC Posted May 25, 2009 Report Share Posted May 25, 2009 Hey, I stuck a 5 speed tranny on a 1600 motor. When I tried to install the clutch slave cylinder, after opening the bleeder valve all the way, i couldn't get the slave cylinder on. I didn't change anything out as far as the throw out leve or bearing and the lever don't have any play at all to beable to put the slave cylinder on. Quote Link to comment
SurgeL320 Posted May 25, 2009 Report Share Posted May 25, 2009 as far as the throw out leve or bearing and the lever don't have any play at all to beable to put the slave cylinder on. I have the opposite problem :confused: too much play and it doesnt engage the throwout bearing at all. Im gonna drop the tranny in the morning to see whats up :blink: Quote Link to comment
datzenmike Posted May 25, 2009 Report Share Posted May 25, 2009 Hey, I stuck a 5 speed tranny on a 1600 motor. When I tried to install the clutch slave cylinder, after opening the bleeder valve all the way, i couldn't get the slave cylinder on. I didn't change anything out as far as the throw out leve or bearing and the lever don't have any play at all to beable to put the slave cylinder on. I have the opposite problem :confused: too much play and it doesnt engage the throwout bearing at all. Im gonna drop the tranny in the morning to see whats up :blink: In both cases the throw out or release bearing housings must match the clutch size on the motor. The housings are of different lengths to reflect the different pressure plate heights. A taller PP needs a shorter housing: a shorter PP needs a taller housing. With the 5spd on a 1600, the 1600 release bearing and housing should be used. Quote Link to comment
LCDC Posted May 25, 2009 Report Share Posted May 25, 2009 so that means i need to drop the drive line, unbolt the the tranny slide it back and swap out throw out bearings. well, with the electrical problems and now this................................................. Quote Link to comment
datzenmike Posted May 25, 2009 Report Share Posted May 25, 2009 As long as you are using the L16 throwout and sleeve it should work. This was a 5spd swapped onto a '73 620? Quote Link to comment
SurgeL320 Posted May 26, 2009 Report Share Posted May 26, 2009 As long as you are using the L16 throwout and sleeve it should work. Hey mike , in my situation with the completely loose clutch fork the only way this can happen is if someone installed it wrong in the first place right? I mean the throwout doesnt just fall out or jam up does it ? If i replace the throwout bearing will it fix my problem . I just wann see this thing rolling Quote Link to comment
datzenmike Posted May 26, 2009 Report Share Posted May 26, 2009 Have someone work the clutch while you watch the clutch slave. It should move the full range of the clutch lever on the tranny. Make sure of this first before pulling the tranny as you may simply have air in the hydraulic system or a non functional master. Quote Link to comment
SurgeL320 Posted May 28, 2009 Report Share Posted May 28, 2009 Have someone work the clutch while you watch the clutch slave. It should move the full range of the clutch lever on the tranny. Make sure of this first before pulling the tranny as you may simply have air in the hydraulic system or a non functional master. Genius!:D I vise-gripped the clutch fork and was able to pull it back, sucker was hard to move back . It WAS my slave cylinder afterall. I cleaned and put in a decent piston and seal. 1step closer to getting it running:lol: Quote Link to comment
LCDC Posted May 28, 2009 Report Share Posted May 28, 2009 As long as you are using the L16 throwout and sleeve it should work. This was a 5spd swapped onto a '73 620? Yeah, but didn't put the sleeve and bearing on from the 4 speed. Atleast we got the wiring issues fixed, for the most part anyway. Quote Link to comment
LCDC Posted May 28, 2009 Report Share Posted May 28, 2009 Genius!:D I vise-gripped the clutch fork and was able to pull it back, sucker was hard to move back . It WAS my slave cylinder afterall. I cleaned and put in a decent piston and seal. 1step closer to getting it running:lol: I can pull the clutch fork back with channel locks, but its so tight moving it that even if in some way I was able to get the slave cylinder on, and if it pushed it back, i think that truck would take off so fast it would give you whip lash. Quote Link to comment
Guest DatsuNoob Posted June 10, 2009 Report Share Posted June 10, 2009 I'm using a 240sx clutch kit on my KA24de w/Z24 bell and ZX 5 spd. I noticed after pressing the KA bearing onto the ZX sleeve, that the front lip of the sleeve stuck out of the front of the bearing pretty good when fully seated. The ZX bearing is also a bit slimmer than the KA one when measured with the calipers.They look very different too. My question is, should I use the sleeve and bearing that match the clutch, or will I be okay to use the ZX sleeve with a ZX bearing on a KA clutch? Does it HAVE to match for it all to work? Thinking yes, but need some confirmation. Mike?? :lol: Thanks Quote Link to comment
datzenmike Posted June 10, 2009 Report Share Posted June 10, 2009 As long as the KA and the ZX clutchs are the same size diameter it should. Probably 225mm for the cars. Quote Link to comment
Farmer Joe Posted June 10, 2009 Report Share Posted June 10, 2009 see now i dont see how this all has to work? when i swapped the 5 speed in my truck i used a z24 flywheel, clutch and pressure plate. then i iused the same TO bearing that was with the 5 speed when it was on the L20b that i got the trans from. so z24 clutch and PP and L20b TO bearing. it works just fine. Quote Link to comment
