freaky510 Posted August 28, 2007 Report Share Posted August 28, 2007 I have a 1977 L20b and a 79 280zx 5 speed which t/o bearing do i use i had the clutch re surfaced and the fly wheel. i have used the smaller one and the larger one and it does not seem to be pushing on the clutch i had Otts friction in Portland do the clutch (Kevlar) so any help please i just want to drive my car Thanks all Freaky Quote Link to comment
kiznook Posted August 28, 2007 Report Share Posted August 28, 2007 you need the TO to match the tranny/ pressure plate combo if I'm not mistaken. I don't have much room to talk, my car has a centerforce TO bearing on an oem clutch/PP, but hey it was free with the car, I can deal with the sound :D Quote Link to comment
freaky510 Posted August 28, 2007 Author Report Share Posted August 28, 2007 thats what i need to know the trans is off a inline 6 and i dont think that nissan put a zx 5speed on a l20b.So do i need to change to the zx fly wheel for it to work. shit the damn thing worked just fine behind a l18 Quote Link to comment
ppeters914 Posted August 28, 2007 Report Share Posted August 28, 2007 If Doug doesn't answer sooner, check the archives on the Bluebirds and/or NWDE lists as that info is in there. IIRC, Bluebirds should have a link/chart to what came with what and what fits what. Quote Link to comment
slodat Posted August 28, 2007 Report Share Posted August 28, 2007 The throwout bearing is matched to the CLUTCH, it has zero to do with the trans. So, if you have a 200mm clutch, t/o sleeve & flywheel (stock 510 size clutch) you use a stock 510 t/o bearing. If you have a 225mm setup (ZX) then you use the ZX t/o bearing & sleeve. Quote Link to comment
kiznook Posted August 28, 2007 Report Share Posted August 28, 2007 yeah, thats it. I knew it was one or the other...brain fart! Quote Link to comment
freaky510 Posted August 29, 2007 Author Report Share Posted August 29, 2007 i dug around and found the bigger T/O. had to get some nuts and push a little harder and it worked out. thanks for the info now i know which one to order. Quote Link to comment
