KA620 Posted May 14, 2009 Report Share Posted May 14, 2009 1971 Datsun 510 The car originally was a 4dr but the previous owner removed the rear doors and welded the seems shut so it is now a 2dr car. The box widebody kit was installed and put on by the previous owner. The body work on the car is not perfect by any means nor was it intended to be. From far the car looks great but up close you can notice all the blemishes in the body work. It does not have any rust anywhere and the car tracks straight as an arrow. It is modified with a 280ZX rear subframe and rear brakes and was converted to use Subaru shock/spring combination in the rear. The front end has 280ZX struts that were sectioned and coilovers were installed with 275lb springs in the front with adjustable camber plates and Tokico Illumina shocks. Also, it has 280zx front brakes with cross-drilled and slotted rotors and Axxis Deluxe brake pads. We also were able to modify a Datsun B210 Booster to work with the larger 15/16" master cylinder. There is also a Wilwood proportioning valve inside the cockpit next to the shifter. The 510 was modified with a 240Z Front crossmember and rack and pinion setup as well. Both the hood and trunk have been completely skinned and are mounted by pins only. The engine only has about 100 miles of street driving so far and is modified as follows with all new parts: `92 KA24DE engine and 5spd transmission `Electromotive TEC2 Standalone management `Odyssey PC680 battery `RCI 10 Gallon Fuel cell `Walbro GSL392 Fuel pump `GSXR 1000 Individual Throttle Bodies `Custom Velocity Stacks `SR20det 370CC Injectors `C's style short shifter `Block was bored and honed .020" `11:1 Compression SOHC Pistons `OEM Water pump `OEM Oil pump `OEM Timing set installed `Custom header to full 3" straight exhaust (Side exit in front of rear wheel) `Aluminum radiator with dual 12" Range Rover fans `Aluminum radiator overflow tank `XTD Aluminum Flywheel `XTD 6-puck Clutch `R200 Welded 4.11 Differential The interior of the car is also nicely fitted with a 240sx tilt steering column. Brand new Sparco steering wheel, Sparco 4-pt Camlock harnesses, Sparco Globe-R Shift knob, 5-in-1 Gauge cluster. The seats are F1Spec Type 2 seats. Also has a 6-point welded cage and the car is structurally very firm. There is a push start ignition system with a fuel-pump cut-off and the toggle switches are for the headlights, fan and turn signals. The wheels are Sportmax 002 16x8 (O offset) with Advan A032R tires (225/50/16) There is absolutely nothing wrong with this car and has been very mildly street tuned and needs a final dyno tune for optimum efficiency and power but do not have the time for this car anymore. It is also licensed and registered for the street. Price: $7800 OBO On to the pictures finally: Link to comment
datto510 Posted May 14, 2009 Report Share Posted May 14, 2009 Hainz is going to love this one!:D Link to comment
banzai510(hainz) Posted May 14, 2009 Report Share Posted May 14, 2009 I like but doesn need windows and bumpers. I dont like the dash set up but its a cool car. Price is not bad either Link to comment
dat521kid Posted May 14, 2009 Report Share Posted May 14, 2009 what about the MAF, is it not needed in this set up with ITB's? Link to comment
BACARDI_DWB Posted May 14, 2009 Report Share Posted May 14, 2009 no maf needed with his standalone TEC2 unit Link to comment
72240z Posted May 14, 2009 Report Share Posted May 14, 2009 what about the MAF, is it not needed in this set up with ITB's? You cant use a maf on itb without a box. He is using a MAP sensor, you can see it bolted to to the firewall. Just fyi Link to comment
KA620 Posted May 14, 2009 Author Report Share Posted May 14, 2009 Yes the standalone runs off of a 3 bar map sensor... Again the car is only mildly street tune and does not have a complete dyno tune. Link to comment
dat521kid Posted May 14, 2009 Report Share Posted May 14, 2009 oh i see.. thanks guys Link to comment
VRTSid Posted May 14, 2009 Report Share Posted May 14, 2009 what a beautiful setup... mmm I love the hood :) gluck on the sale! Link to comment
KA620 Posted May 22, 2009 Author Report Share Posted May 22, 2009 Forgot to mention that the car also has: `Brian Crower Stage 2 Cams 264/264 Link to comment
LCDC Posted May 22, 2009 Report Share Posted May 22, 2009 I love how the dashboard has been peiced together. Is that one of those drycell batteries in there? I figure it must be otherwise there would be a leakage issue. Is the snail Included? Link to comment
72240z Posted May 22, 2009 Report Share Posted May 22, 2009 I didn't notice the snail lol. It's going to throw off the balance!!!! :lol: Link to comment
KA620 Posted May 22, 2009 Author Report Share Posted May 22, 2009 HAHAHA I noticed the snail after i had already taken the picture and figured it gave the car more character. The Odyssey batteries are dry cell :) Link to comment
KA620 Posted June 3, 2009 Author Report Share Posted June 3, 2009 Still available and awaiting offers!!! Link to comment
ichorid Posted June 4, 2009 Report Share Posted June 4, 2009 if you dont sell it soon what are you going to do? Id be interested in harvesting the ITB setup and cams for my KA510, the seats as well. Think aboot it. Hell Id even take the full engine/tranny if you are going to let it go. Keep her as a spare/side build or something.... Link to comment
KA620 Posted June 4, 2009 Author Report Share Posted June 4, 2009 If i dont sell it then the price on the complete car will be brought down. I will not part out the car as i dont need anything from it and need it out of my house already!!!! Reasonable offers are entertained. Link to comment
ichorid Posted June 4, 2009 Report Share Posted June 4, 2009 DARN, any one want to group buy and harvest? some one has to need parts that I dont off the beut. Link to comment
KA620 Posted June 19, 2009 Author Report Share Posted June 19, 2009 Price drop!! $7000 obo Link to comment
dimus Posted July 2, 2009 Report Share Posted July 2, 2009 Did you know the posible WHP for this configuration ? Link to comment
Labanon Posted July 4, 2009 Report Share Posted July 4, 2009 I really wish I still lived in the states. Nice ride. GL with the sale man. Link to comment
KA620 Posted July 4, 2009 Author Report Share Posted July 4, 2009 Estimated wheel hp should be around 180-190 on 91 octane pump gas. On race gas it should push well over 200whp with an agressive tune. $6200 takes it home! Link to comment
