SeisVente Posted May 8, 2009 Report Share Posted May 8, 2009 Hey Gang, I'm getting this extremely annoying buzzing' noise coming from my distributor. It gets louder the more I drive, but it sounds horrible. The only time it fades is when I'm shifting into a gear. Can anyone help me diagnose this?? Thanks! Quote Link to comment
ggzilla Posted May 8, 2009 Report Share Posted May 8, 2009 Remove the distributor and turn the shaft by hand. If it is not smooth, you have found the problem. It probably needs grease or a bushing replacement. At worst, something is broken and hitting something. This can happen with 1974-up types when the advance plate ball bearings fall out. Usually it just messes up the dwell. But on a matchbox type (1978-up) it can get as bad as the inductor hitting the stator teeth. Quote Link to comment
SeisVente Posted May 11, 2009 Author Report Share Posted May 11, 2009 Thanks. I worked on it and it looks like the problem was on the vacuum tube on the carb side. Thing was whistling like mad! I'll keep running the truck to see if it comes back again (knock on wood)! Thanks again!! Quote Link to comment
