dat521kid Posted May 5, 2009 Report Share Posted May 5, 2009 i need help from the pros.. how can i tell if its lsd or not?? i have some pics #1 #2 thank you Quote Link to comment
ggzilla Posted May 5, 2009 Report Share Posted May 5, 2009 Hold one of the axle flanges. Turn the input flange. * If both axles turn, and you can't prevent the one from turning it is LSD * if the other axle turns, but the one you're holding stay stopped, it is not LSD Quote Link to comment
dat521kid Posted May 5, 2009 Author Report Share Posted May 5, 2009 Hold one of the axle flanges. Turn the input flange.* If both axles turn, and you can't prevent the one from turning it is LSD * if the other axle turns, but the one you're holding stay stopped, it is not LSD thank you i think i tried that but not sure i'll try it tomorrow Quote Link to comment
banzai510(hainz) Posted May 5, 2009 Report Share Posted May 5, 2009 looks like a R200.maybe R230?????????????has a hump 99% were NOT LSDs Quote Link to comment
Bleach Posted May 5, 2009 Report Share Posted May 5, 2009 That almost looks like an R180 to me... The mustache bar tells me it was previously mounted in a 70's Datsun. If original, none of them were factory LSD. On the super rare chance you found a NISMO unit someone bought aftermarket then test as mentioned above. If you find a 300ZX turbo from the 80's, look for the diff cover with cooling fins (heatsink) in it. That one has a smooth cover. Also, you can just open it up and look if you dont want to turn the input shaft :D Quote Link to comment
dat521kid Posted May 5, 2009 Author Report Share Posted May 5, 2009 looks like a R200.maybe R230?????????????has a hump99% were NOT LSDs That almost looks like an R180 to me... The mustache bar tells me it was previously mounted in a 70's Datsun. If original, none of them were factory LSD. On the super rare chance you found a NISMO unit someone bought aftermarket then test as mentioned above. If you find a 300ZX turbo from the 80's, look for the diff cover with cooling fins (heatsink) in it. That one has a smooth cover. Also, you can just open it up and look if you dont want to turn the input shaft :D thanks guys i'll check it out Quote Link to comment
thisismatt Posted May 6, 2009 Report Share Posted May 6, 2009 Normally I would say not LSD, but what is that coming off the drain plug? That's not stock... Quote Link to comment
hoov100 Posted May 6, 2009 Report Share Posted May 6, 2009 Normally I would say not LSD, but what is that coming off the drain plug? That's not stock... thats a diff temp sender for an aftermarket gauge. (well it looks like one anyways) Quote Link to comment
dat521kid Posted May 6, 2009 Author Report Share Posted May 6, 2009 thanks to all who relied, i tested it like you guys said and sure enough it is not lsd Quote Link to comment
datzenmike Posted May 6, 2009 Report Share Posted May 6, 2009 The N3100 suffix number is used on many of the internal parts of the R-200 diff. Also it looks more like my R-200 than an R-180. I'll say it's an R-200. Here's my 4:11 R-200: http://i138.photobucket.com/albums/q251/datzenmike/diffR-200411001Large.jpg[/img]"] Quote Link to comment
Bleach Posted May 6, 2009 Report Share Posted May 6, 2009 The N3100 suffix number is used on many of the internal parts of the R-200 diff. Also it looks more like my R-200 than an R-180. I'll say it's an R-200. Here's my 4:11 R-200: http://i138.photobucket.com/albums/q251/datzenmike/diffR-200411001Large.jpg[/img]"] To me the R200 looks mostly straight down one side with a bulge to the left. The one below doesn't quite look like it to me but it could just be the angles of the pictures. Quote Link to comment
