Schroeder6th Posted May 3, 2009 Report Share Posted May 3, 2009 1971 510 L-16 Race Engine 5 Speed Trans Gear Reduction Starter with the following Part Numbers: S114-254D iso 142 Measuring from Starter Mounting Surface to the back of the Flywheel = 15/16 Flywheel Width = 1/2 Nose Gear of Starter extends= 13/16 Just Touching The Front of The Flywheel. Need a Nose Gear That Extends 1/8 plus Bench tested Starter, extends fully. Need a Starter with Extended Reach, Recommendations, Suggestions. Thanks in Advance, Doc Hudson Quote Link to comment
Schroeder6th Posted May 11, 2009 Author Report Share Posted May 11, 2009 both the soliniod and clutch were bad. Replaced Quote Link to comment
