510 adjustable rear suspension
  • Replies 7
This is racer68,s dad I built the suspension! It has 4 1/2 inches of travel on the inside arms and 2 inches on the outside arms. The arms have self aligning bearings and the slotted brackets are 1/4 steel. The inside brackets are bolted so you can shim them to adjust rear toe. I don,t know what type of adjustable beam you,re used to seeing, but this one is more for road racing or drifting.
Thanks for reading
Racecar68dad
