yellowdatsun Posted April 30, 2009 Report Share Posted April 30, 2009 So the fans in the climate control system of the 280ZX's have always sucked, or at least in the 3 I have owned. Wondering if there's an "upgrade" to make more than just a slight breeze come out of the vents. Just doesn't cut it here in Phoenix in the summer. Having the thing turned up all the way is equal to about the number 1 setting in my Frontier. Quote Link to comment
Bleach Posted April 30, 2009 Report Share Posted April 30, 2009 "Auto Climate Control" ?? Is that what you're using? If so, that is your problem not the fan. If the fan receives full voltage it blows air just fine. Yours is probably screwed up. Go with the manual heater control system. (please) Quote Link to comment
yellowdatsun Posted April 30, 2009 Author Report Share Posted April 30, 2009 Nope, mine is manual (thank god). Quote Link to comment
hoov100 Posted May 1, 2009 Report Share Posted May 1, 2009 roll down the windows and remove the t-tops? and 105* is not hot. Quote Link to comment
Skib Posted May 1, 2009 Report Share Posted May 1, 2009 I have manual A/C in my 73' (roll down the windows and drive faster) :lol: Quote Link to comment
420n620 Posted May 1, 2009 Report Share Posted May 1, 2009 mine works great, I've got the 260 AC model :cool: 2 windows down @ 60 mph :lol: Quote Link to comment
yellowdatsun Posted May 1, 2009 Author Report Share Posted May 1, 2009 Umm, I was kinda hoping for some constructive answers. Like maybe swapping the blower out from another vehicle or something, changing the wiring, or whatever. Quote Link to comment
Skib Posted May 1, 2009 Report Share Posted May 1, 2009 thats about as helpful as I am on this one sorry, Iv never owned a car with A/C :lol: Quote Link to comment
Bleach Posted May 1, 2009 Report Share Posted May 1, 2009 1970-78 fans are much weaker than the 1979-83. If your fan is that weak maybe just replace the blower motor itself with a used stock unit. The relays are different on the manual control fan motors so try to get one from the same system. Quote Link to comment
hughdogz Posted May 1, 2009 Report Share Posted May 1, 2009 You could check to see that there are not vacuum line leaks. Also, there is an electric vacuum pump that may not be working properly. I removed the electric pump in my ZXT, so now if I'm in boost, or near 0 psi vacuum, I don't get any flow. :o I have a auto climate converted to manual. Quote Link to comment
yellowdatsun Posted May 1, 2009 Author Report Share Posted May 1, 2009 Ohhh, I have never gotten any flow at/near positive boost. Didn't realize there was an additional vacuum pump for the HVAC. I have checked the system for leaks though using a mityvac, seemed to be fine. Will have to look into that. I assumed that those vacuum canisters under the hood were designed to hold enough vacuum under boost. Mine is an 81' if it makes a difference. Quote Link to comment
SHADY280 Posted May 1, 2009 Report Share Posted May 1, 2009 i have also found that the vacuum actualtors can be an issue. they are the part that controls the flapper doors. if they have a sticky spot they wont open all the way causing poor flow. have the car running or your pump hooked up, remove the dash and watch to verify that all the actualtors are moving full sweep. having the dash out makes it easy to see them all. its pretty hard with the dash in. Quote Link to comment
jknc90 Posted May 1, 2009 Report Share Posted May 1, 2009 In the S30's you can use one from a '95-'99 Maxima. You just have to wire it up and open up the whole that the blower motor fan wheel goes into. Is that constructive enough for ya? lol Quote Link to comment
yellowdatsun Posted May 1, 2009 Author Report Share Posted May 1, 2009 I have an 81, S130, so it was close, but not close enough :-) Quote Link to comment
jknc90 Posted May 1, 2009 Report Share Posted May 1, 2009 Lol, the setups are probably similar between the two models though, but I don't have any S130s anymore so I can't check :( Quote Link to comment
