slam_dat_sun Posted April 29, 2009 Report Share Posted April 29, 2009 OK my 1974 Datsun 620's temp gauge tends to go up to the H every now and again . I put it in the shop and spent almost $1500 on it , I told them to make it a daily driver (DEPENDABLE) . So they put a new radiator on it a electric fan on the front of the radiator that covers the whole thing and a new thermostat. Most of the time the temp gauge stays in the middle , but sometimes it goes to the H . However it does not smell hot but I don't want to blow a head gasket or anything like that PLEASE HELP SHE IS MY DAILY DRIVER :( Quote Link to comment
Skib Posted April 29, 2009 Report Share Posted April 29, 2009 when dose it usually get hot? just driving around? traffic? freeway? did they leave the fan clutch and mechanical fan on? Quote Link to comment
motavated Posted April 29, 2009 Report Share Posted April 29, 2009 My cars is acting funny. Its not hot and yet it says it does. I am going to wire a manual temp gauge for a temporary fix. Buy one for like 10 buxs and drive it around and if it goes up... Then there is something wrong.. Quote Link to comment
pl521sss Posted April 29, 2009 Report Share Posted April 29, 2009 OK my 1974 Datsun 620's temp gauge tends to go up to the H every now and again . I put it in the shop and spent almost $1500 on it , I told them to make it a daily driver (DEPENDABLE) . So they put a new radiator on it a electric fan on the front of the radiator that covers the whole thing and a new thermostat. Most of the time the temp gauge stays in the middle , but sometimes it goes to the H . However it does not smell hot but I don't want to blow a head gasket or anything like that PLEASE HELP SHE IS MY DAILY DRIVER :( Radiator, fan and new thermostat for $1500!!! :eek: when it goes to H, can you hear the fan running? Quote Link to comment
Lozer Posted April 29, 2009 Report Share Posted April 29, 2009 Ill do a tune up for 500$ and you buy the parts. That should fix it :lol::lol::lol::lol: man shop around before you drop that much dime. I hope it's a griffon radiator and a top of the line rolls royce fan set up. Quote Link to comment
lynchfourtwenty Posted April 29, 2009 Report Share Posted April 29, 2009 lmao im sorry but $1500 is alot of money to make a datsun dependable.. you could prolly make 2-3 datsuns dependable with that cash.. im not tryin to diss but workin on these rigs is easy, very easy... as for your problem, when does it happen??? hot days? cold days? while driving?? while stopped?? Quote Link to comment
Skib Posted April 29, 2009 Report Share Posted April 29, 2009 lol that is alot, but lets not stray from the topic to much :lol: the more info you can give the better we can help :D Quote Link to comment
Pacific coast Datsun Posted April 29, 2009 Report Share Posted April 29, 2009 Lots of variables here..we need specific details as mentioned above. Could be a bad stat, collapsing lower hose, not enough anti freeze etc... Quote Link to comment
sanitys Posted April 29, 2009 Report Share Posted April 29, 2009 (edited) mines goes hot sometimes, but then again its revving reallly high doing 85 on the freeway. Ive replaced the thermostat and flushed the system. I havnt quite determined what the culprit is to be honest. Today on the way to work i blew a heater hose, barely made it to work...stop and go traffic, had to shut it off, start it, etc. I would just replace all the cooling system components one by one, but Im searching for a decent priced ka24e swap so ill replace as need be untill i can find one at a reasonable price, was looking for a 91-97 hardbody for parts...or not, but for the motor trans...no way in hell im paying 3k for a dropped (spindled/leafed) hardbody, thats rusted and dented and spray painted flat black... enough off topic ranting, if you have a new rad, fan, thermostat, and your still overheating, what does that leave you? head gasket or waterpump issue, thats all i can think of...unless your temp sensor is shot ...or you have no oil, but i doubt your motor would last long...you get the point Edited April 29, 2009 by sanitys Quote Link to comment
moparvwfreak Posted April 29, 2009 Report Share Posted April 29, 2009 temp sensor could be flaky. also check the wiring. i know my 78 does that but i have leaky radiator. also check the cap pressure. my 78 , when i got it was running a 20lb cap, and it should be a 13lb cap. i know you say its got a new rad, new fan, new t-stat. hows the water pump?? hoses?? Quote Link to comment
lynchfourtwenty Posted April 29, 2009 Report Share Posted April 29, 2009 ya u cant always trust datsun wiring... in my truck theres only 3 things u can rely on, an none of them are stock datsun lmao!! tach, temp, oil pres. gauges they've saved me a few times :) an the tach is my speedo hehe Quote Link to comment
ggzilla Posted April 29, 2009 Report Share Posted April 29, 2009 I doubt if it is heating up. More likely the wire at the engine is not tightly fitting. Make sure it fits tight, and crimp it if needed. Quote Link to comment
zed Posted April 29, 2009 Report Share Posted April 29, 2009 (edited) My Toyota truck temp guage would shoot into the red suddenly. Real frightening it was. BUT it was not overheating - the engine earths(ground) were bad, causing current to run through the gauge. Next time it overheats, open the hood and grab the inlet and outflow pipes from the rad - feel if the water is being cooled by the rad or not. Edited April 29, 2009 by zed Quote Link to comment
Pacific coast Datsun Posted April 29, 2009 Report Share Posted April 29, 2009 I tend to agree with the opinion that your stock gauge may be the problem. You can install an aftermarket one w/ the probe that goes into the radiator & eliminate that issue. Quote Link to comment
datzenmike Posted April 29, 2009 Report Share Posted April 29, 2009 The sender grounds the gauge to produce a reading. If you have a loose wire it will read cold! Check that the wire to the sender isn't bare and touching ground anywhere which would produce a hot reading. Quote Link to comment
HRH Posted April 29, 2009 Report Share Posted April 29, 2009 Could also be your carb is too lean. Is it original or are you running a Weber? And 116 degrees in Phoenix tends to tax cooling systems way more than up here. (Used to live in Mesa for a year) My hardbody never had problems, but even in Spokane, my 620 gets up to the H if I keep it pegged to the floor on the freeway on really hot days. So I cruise at 75 instead and she's okay with that. But anyway, we need more information on when your truck is overheating and what all has been done. Quote Link to comment
lynchfourtwenty Posted April 29, 2009 Report Share Posted April 29, 2009 i say no one else reply till he does.. lol Quote Link to comment
slam_dat_sun Posted April 29, 2009 Author Report Share Posted April 29, 2009 (edited) when dose it usually get hot? just driving around? traffic? freeway? did they leave the fan clutch and mechanical fan on? the factory fan is one it has a electric fan now . It got hot driving about 35 mph going to work Edited April 29, 2009 by slam_dat_sun add text Quote Link to comment
lynchfourtwenty Posted April 29, 2009 Report Share Posted April 29, 2009 check the wiring for the temp sender by where the top radiator hose goes, and also make sure that electric fan is turning on an off when its suppose to oh an check your coolant :) Quote Link to comment
hang_510 Posted April 29, 2009 Report Share Posted April 29, 2009 It got hot driving about 35 mph going to work HOT as read from the gauge? any way to verify the temp at the time w/an external thermometer? water pump turns freely and the belt is tight? still sounds like a bad NEW thermostat... Quote Link to comment
slam_dat_sun Posted April 29, 2009 Author Report Share Posted April 29, 2009 Radiator, fan and new thermostat for $1500!!! :eek: when it goes to H, can you hear the fan running? well i had a lot more work done than that for $1500 im not stupid :lol: . i have the adjustable switch on it and it kicks on at 160 degrees Quote Link to comment
slam_dat_sun Posted April 29, 2009 Author Report Share Posted April 29, 2009 lmao im sorry but $1500 is alot of money to make a datsun dependable.. you could prolly make 2-3 datsuns dependable with that cash.. im not tryin to diss but workin on these rigs is easy, very easy... as for your problem, when does it happen??? hot days? cold days? while driving?? while stopped?? i realize that they are easy to work on bot i work many many hours a day and dont have time to do it myself , hell i got a huge tool box that you cant tell what color it is due to the thickness of dust:blink: Quote Link to comment
slam_dat_sun Posted April 29, 2009 Author Report Share Posted April 29, 2009 Lots of variables here..we need specific details as mentioned above. Could be a bad stat, collapsing lower hose, not enough anti freeze etc... well the hose is good , I put 2 different stats in it and its nothing but antifreeze in it Quote Link to comment
slam_dat_sun Posted April 30, 2009 Author Report Share Posted April 30, 2009 sorry i haven't replied sooner I am a trucker and i dont carry a computer on my truck Quote Link to comment
lynchfourtwenty Posted April 30, 2009 Report Share Posted April 30, 2009 50/50 antifreeze correct? i would try gettin a aftermarket gauge an see whats really goin on.. thats what i have in my truck, got an oil pressure gauge too Quote Link to comment
