rookie
frank k
  • Replies 17
Hi frank, welcome to ratsun.
Ratsuners, what do you think about this "all rebuilt" matchbox distributor?
http://datsunpartsllc.com
* $175.00
* Completely Rebuilt Using All New And Reconditioned Parts
* You Will Need To Buy A L28 Distributor Base Too
* A Stock Tachometer Will Not Work With This Setup
I know you can get these as cheap as $35 from wreckers (i've bought 'em for that price) but a new Vacuum advance is $30+ and new advance bearing plate is $75. Most used ones have bad advance and bearing plate. So this price sounds fair for all rebuilt with warranty.
New Cap & rotor is $14 at Rockauto.com
* $175.00
overpriced!
rockauto still has them for ~$130, basicly new w/warranty.
i got a new unit a few months ago @ close out for $65 :D
i have a used matchbox avail as well as a single point.
many thanks to those who provided info. I think I know what I want to and need to do about the El. Dizzy. Also have a (minor) problem that when I turn on a turn signal, left or right, both flash. I found a flasher available for bidding on Ebay. From Singapore, 11 WEEKS for delivery! I passed. Will also post photos when my computer geek helps me figure out how to do that.
