DatDoug Posted August 21, 2007 Report Share Posted August 21, 2007 I have a Canon but I have heard they are not a good design. What are my other options for my L20 and where can I find them? Quote Link to comment
banzai510(hainz) Posted August 21, 2007 Report Share Posted August 21, 2007 I have seen people run the Cannon but I heard the Lynx X over manifolds are the one to get if you can find one. They are Aussie or english ,at least the ones I saw. It has some thing to do with the intake pulse or mixture not being right on the 2 inner cylinders. Quote Link to comment
DatDoug Posted August 21, 2007 Author Report Share Posted August 21, 2007 I put the manifold and carb on yesterday & it definitely livened up the ol L20! Can't quite get her tuned just rite tho. Its weird the car sounds and reacts totally dif. Quote Link to comment
Duke Posted August 21, 2007 Report Share Posted August 21, 2007 The problem with the single manifolds is that the outer two cylinders run lean. The fuel distribution isn't even across all cylinders because of the design of the manifold. It will run fine, but that is the downside of the cannon manifold and why people knock it. Quote Link to comment
datsunfish Posted August 22, 2007 Report Share Posted August 22, 2007 I would assume that the cannon would be similar to a set of su's.No x flow on those either.Never ran either just seems to make sense.You might need a synchronizer tool on a single to adjust each side.What cam are you running?Might be a bit much for a stocker. Quote Link to comment
