Sealik Posted November 15, 2009 Report Share Posted November 15, 2009 ..........."Well, since you're riveting it, you can redo it if it's not stable enough. I used the side of a computer case on the first one....it wobbled....that's why this one got the 16ga You could use some angle or bend a couple of strips of sheet metal to make angle and rivet those across, just outside the mounting holes...might make it more rigid without having to completely redo it." Thinking I could have cardboard in there.....:lol: Being mounted to the valve cover and all. The pot lid....in theory.....should 'somewhat' counter the wobble.:D Quote Link to comment
Sealik Posted November 15, 2009 Report Share Posted November 15, 2009 Maybe. I could be wrong....if not right. Or left:D Quote Link to comment
mklotz70 Posted November 15, 2009 Author Report Share Posted November 15, 2009 oh ya....bolted to the valve cover ought to help :) 1 Quote Link to comment
Sealik Posted November 16, 2009 Report Share Posted November 16, 2009 Decided to make another plate for the base of the air cleaner. No wobble now..............:D Riveted that on. Fits rather well.....just have to clean everything up....then rattle can it:cool: Oh......and also mount the Weber and remove some emissions from engine. EIA tubes from the EM will be hooked up....but plugged. Not sure yet about the ATC....it's the vacuum motor at the end of the air cleaner. Good for cold starts......engine will run leaner......but???? Eliminate? Quote Link to comment
mklotz70 Posted November 16, 2009 Author Report Share Posted November 16, 2009 That came out sweet! As for the ATC...it also helps keep the temp in the air cleaner high enough to keep the carb from icing up. If you were worried about air flow, you wouldn't be running a stock air cleaner :) If it was a show truck more than a driver, I'd ditch it, but it's a driver....keep it :) 1 Quote Link to comment
Sealik Posted November 16, 2009 Report Share Posted November 16, 2009 (edited) Actually...wasn't thinking about the air flow from the stock air cleaner. Just couldn't afford to buy a Weber AC right now:( But....I was out today....in another 720. I know the ATC is not functioning properly because I plugged all (most) of the vacuum (emission) hoses on the stock Hitachi The truck has been underpowered lately...(winter).....then all of a sudden it would start missing, big time. No power. Black smoke is belching out...turn it off.....pop the the hood....ice on the carbs base plate. Wait a minute......flashes right up.....good to go. Happened twice so far. ATC....? Edited November 16, 2009 by Sealik 1 Quote Link to comment
mklotz70 Posted November 16, 2009 Author Report Share Posted November 16, 2009 On the base.....I'm thinking the hot water running through the manifold should stop that from happening.....did someone bypass it? 1 Quote Link to comment
Sealik Posted November 16, 2009 Report Share Posted November 16, 2009 Well ....if some one did....it was me.:lol: Other than the emissions..(hoses).....nothing has been touched. Thinking that the length of the snorkel on the air cleaner drawing cold air in would contribute to the ice.???? Relative to being heated by the EM Not knowing......just a guess.:blink: 1 Quote Link to comment
mklotz70 Posted November 16, 2009 Author Report Share Posted November 16, 2009 Black smoke is too much gas....so maybe the choke is sticking closed? If the ATC were working, the length of the snorkel wouldn't matter as much. Check the emissions hoses....I wouldn't be surprised if you have a water valve controlled by them that would heat the intake. 1 Quote Link to comment
Sealik Posted November 16, 2009 Report Share Posted November 16, 2009 Initially I thought it might be the accelerator pump.....or choke But.....It was wide open.....no leaks around carb....couldn't check the sight (dot) glass to confirm flooding. Carb might be partially NFG. Might have to put that Weber and air cleaner on....help make it through it's last winter;) 1 Quote Link to comment
mklotz70 Posted November 16, 2009 Author Report Share Posted November 16, 2009 About out of ideas at this end. 1 Quote Link to comment
reese Posted December 30, 2013 Report Share Posted December 30, 2013 http://www.jameng.com/product_images/l/440/99010.301__72769_zoom.jpg Has anyone used this Weber adapter on an L16 powered 510? Did it the air cleaner hit the hood? 1 Quote Link to comment
Just Joel Posted December 30, 2013 Report Share Posted December 30, 2013 On an l16 you should be fine ;) 2 Quote Link to comment
Stewiefied Posted December 24, 2014 Report Share Posted December 24, 2014 love this idea 1 Quote Link to comment
LTJ Posted August 22, 2016 Report Share Posted August 22, 2016 I had the idea to do this about a year ago, then I join up here a couple of days ago and see that many others have beat me to it! Ah well, at least now I know it works! Thanks for the write up! 1 Quote Link to comment
mklotz70 Posted August 22, 2016 Author Report Share Posted August 22, 2016 I was checking on something....found that the links from all the thumbnails on page one are bad. Going to repost fresh links. I tried to edit what was there without any luck. http://s88.photobucket.com/user/mklotz70/library/Projects/stock%20air%20cleaner%20mod/aircleanerVer2?sort=2&page=1 ....after several more failed attempts....keep getting the "can't use this file extension" or something to that effect......I decided to just post a link to the PB album where the vids are. What's the deal with ratsun not posting vid links from PB? Seems to work sometimes, but typically not. 2 Quote Link to comment
Charlie69 Posted August 23, 2016 Report Share Posted August 23, 2016 Mike I have had to re do pictures in my posts over the years. seems like some are affected by software updates. I just edit the post by deleting all the bad pictures and then paste the new links back in the post. This is the only way I have been successful in getting the pictures to work. You have to be sure and highlight all of the code for each picture and hit the delete key on your keyboard or right click delete. 1 Quote Link to comment
Charlie69 Posted August 22, 2017 Report Share Posted August 22, 2017 Mike Videos are not working for version 2 would it be possible to put this how to on your Blue Hands Inc website? Thank you for your time. Quote Link to comment
SunnyDaze Posted November 29, 2017 Report Share Posted November 29, 2017 Similar mod done on an A-series, using the Redline adapter to 5 1/8". http://datsun1200.com/modules/newbb/viewtopic.php?topic_id=69475 1 Quote Link to comment
Gluteus Maximus Posted July 23, 2023 Report Share Posted July 23, 2023 I bought a stock airfilter assembly at the Powerland show to try and do a mod for the Weber, but don't have a welder or cutting tools. Has anyone use this adapter with success? My 620 has the L18 and I was hoping this would be the easiest option. https://www.ebay.com/itm/202369453365?chn=ps&_trkparms=ispr%3D1&amdata=enc%3A1ujowZhNOQOeb4pbDtSKAgw16&norover=1&mkevt=1&mkrid=711-117182-37290-0&mkcid=2&mkscid=101&itemid=202369453365&targetid=1644837435723&device=c&mktype=pla&googleloc=9032937&poi=&campaignid=20125739985&mkgroupid=149128855676&rlsatarget=pla-1644837435723&abcId=9312975&merchantid=113691383&gclid=Cj0KCQjwn_OlBhDhARIsAG2y6zMYysbsOKdU5-vnSx14NIenWo8aMT4wWe1hROhNEJDriA3wXRtG93saAgglEALw_wcB Quote Link to comment
datzenmike Posted July 23, 2023 Report Share Posted July 23, 2023 Yeah that should work. Quote Link to comment
banzai510(hainz) Posted July 23, 2023 Report Share Posted July 23, 2023 (edited) its not exact as the weber is raised compared to the stock bracket that goes to the intake but will fit the main airfilter housing. Its quieter that the weber airfilter and more common replacement. I like them!!!!!!!!!!! but throw or gave all away I have the Tall Weber adpater and I think I would hit the hood anyways Edited July 23, 2023 by banzai510(hainz) 2 Quote Link to comment
