spottedog Posted April 13, 2009 Report Share Posted April 13, 2009 1980 Datsun 720 Kc pickup 4WD (yeah, it Quote Link to comment
hang_510 Posted April 13, 2009 Report Share Posted April 13, 2009 adjust it tighter! Quote Link to comment
nis720 Posted April 13, 2009 Report Share Posted April 13, 2009 I had a problem with mine... it ended up being the adjustment where the rear cable neet the hand brake cable. There's a nut in one of them that might need to be cranked. Quote Link to comment
datzenmike Posted April 13, 2009 Report Share Posted April 13, 2009 adjust it tighter! Yeah. As long as when you release the hand break the shoes are not dragging then good. If it only comes out 3-4 clicks it doesn't matter. Eight clicks to lock it tight enough to keep from turning by hand is nothing. Quote Link to comment
datsunaholic Posted April 13, 2009 Report Share Posted April 13, 2009 I've seen that when the shoes are put on backwards. The linings are "clocked" a certain way for a reason. Typical symptom of that is they'll hold one direction but not the other. Another cause is drums that are too far worn- you said they've been turned, which increases the inner diameter. It takes a while for the shoes to "wear in" to the larger diameter. Oh, and when putting new shoes on you have to adjust them after driving them a couple miles- they never seem to "center" without doing some forwards/backwards/parking brake pull stops. Quote Link to comment
datzenmike Posted April 13, 2009 Report Share Posted April 13, 2009 Good one Doug. Brakes never work as good backing up. Quote Link to comment
Wharf Rat Posted April 13, 2009 Report Share Posted April 13, 2009 Yank on it :lol: Quote Link to comment
N0RCALDIME Posted April 17, 2009 Report Share Posted April 17, 2009 mine were like that on the 510. i just got underneath the car and tightened the cable where the two connect and now the handle is tighter and i can park on any hill. it still doesnt stop the car completely when you yank it while in motion but i have a steep ass driveway. just tighten the fucker. thanks for no word filters ratsun. Quote Link to comment
slodat Posted April 17, 2009 Report Share Posted April 17, 2009 It is important to note that these are parking brakes, not emergency stopping brakes. While they can and will slow/stop a car, that is not their primary intended function... Quote Link to comment
nis720 Posted April 22, 2009 Report Share Posted April 22, 2009 Today I felt the urge to drive my 720 and snapped a pic of the adjustment I was talking about. I also adjusted it, and it's much better now. Quote Link to comment
Wharf Rat Posted April 22, 2009 Report Share Posted April 22, 2009 Good to hear that :) Quote Link to comment
MikeRL411 Posted April 22, 2009 Report Share Posted April 22, 2009 Probably not the case here but often stepping on the brake pedal and then applying the parking brake as you release the pedal sems to result in a more positive parking brake engagement. [in my old Corvair this was the only way the parking brake would engage] Quote Link to comment
fastdadd Posted April 22, 2009 Report Share Posted April 22, 2009 Not having a working parking brake while off roading is a safety hazard! so does having low profile street tires:lol: Quote Link to comment
Datsun fan Posted May 11, 2009 Report Share Posted May 11, 2009 I have the same fucking problem with may Mazda and Datsun trucks and I gave up 2 yrs ago . And for new shoes , I always install them clockwise and counter-clockwise without any minor diffrent in performance ???!!!! Quote Link to comment
