Powdercoating a Header?
  • Replies 12
you want it ceramic coated
about 100-150 $
heres one done.
cost more then the header itsself.
this header is used for show as they are a little bit of a loose fit and never ran one myself. Others have said they are OK ,others say they could leak.
I got mine from Dave Turner Motorsport but TOP END PERFORMANCE sells them. they have a cheap paint job. everybody wished they had them coated after the fact,when they start geting surface rust on them.
here is where I got mine done in Auburn ,Wa I did front covers and oil pans also. best to leave the dizzy mount and water port also so they can get coated at the same time as they go by psc and size.
http://www.performancecoatings.com/index2.html
Edited by banzai510(hainz)
i work at a powder coating place and have powdercoated a few headers of my own for experiments with high heat and they eventually failed. i agree go with ceramic coating, i will be doing this one day but for right now i am not but i do offer lots of other powdercoating options for everything else datsun realted ......and can answer most any paint of powder related questions if you ever have any. thanks jon
http://www.ctspecialties.com
Most powder coating companies only heat up to 300-350. Headers run way hotter than that. So probably burn off too.
Larry
powder is cured at 400 for 25-30 mns fuill cure still not hot enough for a header. anyone who gets theres cured at 300-350 is runnin undercured powder that will fail and flake off due to under liquification making it brittle and subject to heavy chippin
Ceramic coating all the way.
Here's my current headers after 6 years of use (on my friends truck)
After some polishing. (on my truck now).
i agree cermaic is the best option.. nice motor and header though.....so if you dont mind me asking how come trailer fenders for inner fenders and stock front suspension on truck?
Thanks for clearing it up. I just knew that the PC fails on headers
Larry
