datzenmike Posted March 14, 2009 Report Share Posted March 14, 2009 (edited) http://i138.photobucket.com/albums/q251/datzenmike/Tranny/83FS5W71Bshorttail001Large.jpg[/img]"] Well I finally have one. First one I have ever seen! I knew they existed on the 720 trucks but which ones got it? I haven't figured out yet. I had an '82 2wd that was long and an '80 4X4 that was long. This was an '83 KC 4X4 so maybe only 4X4s? It's 26" so would fit a 510. Hint hint. I have a spare L front case for it. The problem is the rear case has no speedo outlet. more later... Edited March 14, 2009 by datzenmike Quote Link to comment
LenRobertson Posted March 14, 2009 Report Share Posted March 14, 2009 I'm sure envious. I thought those only came in early 4X4 720s that used the L20 engine. However, I've looked at a couple of '79 4X4s with L20s that had longtails. If yours came from an '83, does it have the bell housed tilt for Naps-Z series, rather than L20? Or had someone swapped an L series into that truck? Maybe I need to measure the trans in every year 720 4X4 at Pull n Save. Len Quote Link to comment
datzenmike Posted March 14, 2009 Author Report Share Posted March 14, 2009 (edited) This was an '83 KC 4X4 so .... Yup, an '83 Z24 motor. I pulled the head as well as the R-180 4:11 front diff. (think it's sold) Got the 4X4 oil sender/ pressure gauge and volt gauge too. Someone told me it was a shorty but it was laying flat on the ground and couldn't get under it to check. Too bad there's no speedo or it would make a fine 5spd swap into a 510. The ratios should be: 1st... 3.592 2nd... 2.057 3rd... 1.361 4th... 1.000 5th... 0.813 R...... 3.657 Len, the only '80 720 4X4 tranny I pulled (still have it) is a long with no speedo drive. I'm fairly sure it was a reg cab. So maybe the shortys are on the king cab and/or long frame.??? Edited March 14, 2009 by datzenmike Quote Link to comment
datzenmike Posted March 14, 2009 Author Report Share Posted March 14, 2009 Here's the R-180 4:11 ratio I scooped also. Nice little addition for a 510? http://i138.photobucket.com/albums/q251/datzenmike/720%20stuff/diffR180411005Large.jpg[/img]"] Quote Link to comment
makya Posted March 18, 2009 Report Share Posted March 18, 2009 You don't happen to know the ring gear diameter and the width of the housing do you? Quote Link to comment
