vindats1 Posted March 3, 2009 Report Share Posted March 3, 2009 Had a couple of guys from my Datsun club come over and we got my little Roadster up and running again. Looks like it needs a new thermostat and hopefully that is all. The temp guage wasn't doing anything and we found out that someone who I won't name (yes, ex husband) broke off the wiring to the temp sending unit when he was fooling with my car and didn't fix it or tell me. So, I will pick up a thermostat today and we shall see if that is all that it needed. Engine has a nice deep rumble and runs nice. We did a compression check too and it came out really good. Happy me! Quote Link to comment
Phlebmaster Posted March 3, 2009 Report Share Posted March 3, 2009 Sweet! Can't wait to see you driving her. :D Quote Link to comment
MikeRL411 Posted March 10, 2009 Report Share Posted March 10, 2009 Had a couple of guys from my Datsun club come over and we got my little Roadster up and running again. Looks like it needs a new thermostat and hopefully that is all. The temp guage wasn't doing anything and we found out that someone who I won't name (yes, ex husband) broke off the wiring to the temp sending unit when he was fooling with my car and didn't fix it or tell me. So, I will pick up a thermostat today and we shall see if that is all that it needed. Engine has a nice deep rumble and runs nice. We did a compression check too and it came out really good. Happy me! If you are unlucky enough to need a thermostat housing there are 2 alternatives to the stock Datsun part if you have a 2 liter radiator. A MOPAR aluminum V6 will work although it has a slightly different exit angle for the upper radiator hose, mounting bolt holes are the right size and spacing. The second is a KIA Sephia housing. Virtually identical to the Datsun part except for a slightly smaller dome and metric bolt holes but on the right location and spacing. Open up the holes with a drill bit and you would have to look closely to see that it wasn't factory original. With the original 1600 roadster radiator there is a MOPAR V8 housing that points straight up and can be mated to an aftermarket generic hose after being butchered with a sharp knife. Quote Link to comment
exit64 Posted March 10, 2009 Report Share Posted March 10, 2009 Is this a 1600 or 2000? With the 2000 you need to use the correct gaskets on the thermostat housing that have the copper in them or you will never get a ground to make the sender work. Don't forget to drive your car and take a picture tomorrow for 311's day. Quote Link to comment
ppeters914 Posted March 11, 2009 Report Share Posted March 11, 2009 I believe Tana's is a 1600. Have heard folks using a copper staple or small wire to ground the 2000 housing. Quote Link to comment
