So I was worried about lateral movement of the linkage when putting this thing together - i cut these with a heat knife until I got the right thickness to put one either side of the linkage before pressing in. I had this poly kit form a suspension off an older VW. These components were for another model and just sitting in my box o' goodies for years... Figured it couldn't hurt.
You can see they barely fit in there - but I couldn't find wave washers the right I.D. for it....
There is no play - at all...
Normally these have an o-ring in them to prevent oil seepage from the lube hole. Seeing as I no longer needed them I thought I'd try something...
Yes, that is an old pressure ring from a 3/4" brake master cylinder...
They fit beautifully inside the steel ring for the striking rod - however the rod itself did NOT want to go through the I.D.without serious stretching - Got them in and then the steel ring was too thick to press properly. I figured if I trimmed them to fit it would work way better than an o-ring, but these were in great shape so I erred on the side of caution and just used the standard o-ring. If anyone has problems with leakage at this spot and you have a set of older seals from a brake master cylinder and want to trim to size, it's an option.
All back together and ready to go in... I pulled the clutch to inspect before I re-installed. Glad I did so because the rear main was not installed correctly by whoever was in there last..
Fixed that and re-installed everything. There is maybe one inch of side to side play at most in the stick now.. mostly from the linkage piece that the stick bolts into - that part is unobtanium new...
Then I tore into this.... another story entirely - and yes, I pulled the bushings - there was unusual wear in two and three from the cam - the whole thing is in the cylinder head shop now getting hot tanked, tested, machined and inspected as I type. It was fun carrying it there on my back.. Alice pack frames are a good thing to have laying around. I did manage to find the missing lash cap as I said earlier, it was in the rear corner of the cylinder head buried in old oil buildup - that could have been really bad.
