To put a inline 6 cyl dat eng into your 720 truck is not worth the hassle. i have a 1980 datsun truck that I have put one into. You run into the domino effect, one problem after another. Without cutting the body you will not have room for a rad or fan. I cut off the rad support and extended the frame. I currently can drive around the around the block on open a-pipe. Just not worth the trouble.... I have decided to make my 720 a rat truck....I strongly advise not to try and shoehorn a Z car 6cyl eng into a 720 truck...As far as pictures go I do not have anuy current ones.....
Will it fit? And what can I do to make it fit, it's pretty long engine for the short nose of a 720! What should I do?
