Coolant Bypass Line
  • Ask for price WANTED
  • Offered by: NC280z
  • 10 days and 49 minutes left ()
Looking for a coolant bypass line for a 280z, specifically the line that runs from the lower coolant intake housing to the underside of the thermostat housing.
You mean the pipe that by-passes coolant from the front of the thermostat housing down to the lower rad hose inlet to the timing chain cover.  I doubt Nissan still has them....
14055-N1400
14055-Y4000
14055-N6900 All the same part just different numbers.
Why not just make one up out of copper tubing? Cheap, easy to bend, paint it silver, no one will know.
NC280z
I've got a bead roller and some tubing, I'll likely fab one up myself. I was hoping to find a stock or used replacement because they also have the mounts that connect it to the cylinder head. Any idea what the stock tubing diameter is?
