ATC intake air sensor for 1985 720
  • Ask for price WANTED
  • Offered by: matrophy
  • 1 day and 15 hours left ()
  • Item Condition NEW
Corvallis, Oregon United States
2 Questions
Trying to adapt my Weber to my stock air cleaner. I want to keep the intake air hot like it came from the factory
and I need this sensor. It was on several Nissan models around 1985 - 1990. Part number is 16580-W7000. It would need to be gently pried from the air cleaner
housing or better yet, I could take an old air cleaner that you may have laying around - assuming it has the sensor in it still. Make me an offer.
Excellent idea. Keeps the ATC functional. On some earlier models there is a thermostatically controlled air bleed. When the under hood temperatures are extreme the air thins out and it will idle richer. This air bleed opens a small leak to the intake restoring the idle mixture.
Overall the stock air filter is not only quieter but cheaper (I think) and lasts longer between changes.
ATC was used on all USA Datsun from 1972 onwards. Though they might be different diameters they look very similar
Test your air cleaner: 1. reach in and push flap 2. Stick finger over motor port. Then release flap. It should hold vacuum. Many of them are leaking after 20-30 years. I have removed the vacuum motor from a newer Datsun and fitted it to a totally different older model
Other adverts from matrophy
