Datsun L18 Engine & Transmission- Running
- $1,500 FOR SALE
Offered by:
Lupine
- 3 days and 3 hours left ()
Specs
- Item Condition USED
- Quantity 1
Datsun L18 and 4-speed manual transmission still in 1974 620 pickup. Engine runs well (even with a clone Weber 32/36 - idles rough with this carb due to a vacuum leak in the adapter). I did a top-end refresh with new gaskets and honed the cylinders (the bottom end looked so good that I did not touch it (other than the required gaskets). All cylinders have a cold compression of 125 - 130psi without additional lube on the rings. Oil pressure is good and there are no defects in the block or head.
I am pulling to swap engines for a little more output.
Interested persons can request video of engine running. Buyer must pick up local in Kansas or pay freight of their choice. Email requests for information at lupine.vir@gmail.com.
