Price drop! L20B 200mm flywheel and clutch w/4 speed
  • $700 FOR SALE
  • Offered by: TheBirdistheWord
  • 1 day and 10 hours left ()
Morgan Hill , California United States
1 Offer
Pretty straight forward
Stock l20B, has an a87 head.
No accessories, comes with front cover.
Junkyard engine I bought years ago, I've personally ran this engine with no issues but I have never opened it up or inspected it past swapping the head/gasket and a compression test. It's never let me down, and I run my engines hard.  Came with a "smog" w58 head so I'm assuming it was in a truck. Timing chain was done with the clutch.
It's installed into one of my cars at the moment for storage sake but is not hooked up to run.  will only remove once I've found a buyer.
Looking for 1000 for the package, willing to deal if I keep the flywheel, oil pan, and or the front cover
How I came to this price:
Short block-300
Head-225
Front cover- 125
200mm Flywheel-175
L16 oil pan-175
Transmission -free (tested at low speeds, 1st and 2nd are fine)
Edit: For anyone that's interested in the package as a whole I'm Willing to throw in driveshaft and r160 to complete the drive line
Assume this is in, or for, a 510. Must be a F4W63 transmission.
W58 heads were used on all L20Bs from '78 through '80 in the '78-'79 S10 200sx, '78-'79 620 truck, '78-79 A10 HL510 and the '80 720 truck. It can be assumed that if it came with a 200mm flywheel then it came out of a car, trucks used 225mm flywheels.
I can tell by looking at it that it's a '79 or '80 engine so it should have a matchbox style distributor.
TheBirdistheWord
Engine came with a 225mm flywheel. I installed the 200mm
Didn't come with a dizzy, but has my matchbox installed on it currently.  Pretty sure I'm keeping that
4 speed did come out of a 69 510
Other adverts from TheBirdistheWord
