Instrument Cluster with Tach
  • Price $1
9 Questions
Looking for a working instrument cluster with tach for a 68-73 Datsun 510.
In all reality, the 510 tack is rare, and if you can find one  that actually works it will cost you the Big Big. There is a Revolution Gauge Tack sold through SpeedHut that fits in the dash and looks pretty close to stock. You can even open the gauge and put any face on you want.
They also make a speedo the same size and face that uses GPS and requires no cable
Also try posting a WTB (want to buy) for the stock 70-73 cluster on the510realm.com. You never know.
Edited by paradime
68 and 69 look similar but are completely different
even the mounting points for the cluster are different
the first pic is a 68 dash
second is a 69
most noticeable difference is vertical heater controls and the added horizontal piece that holds ignition, choke and headlight and wiper switch
the cluster has the switch description for each
the 68 does not and the cluster mounts different
Edited by Ranman72
