72 510 door spring
  • $1 WANTED
  • Offered by: twostrokesmoke
  • 8 days and 18 hours left ()
5 Questions
Hello , looking for one door spring for a 72 two door with the flat washer, thank you. Ted in Portland
Have you ever re-installed one of these springs?  I've never tried, but always thought once gone, need another hinge.....?  I have a box of hinges, will look to see if I have a loose spring!
TJ
twostrokesmoke
Thank you for the thought
i have completely rebuilt the hinges too, usually if a spring falls out it is because the holes and pins in that arms are so worn out they will end up jamming and binding up and require welding fabrication to repair, and yes the springs are hard to put it there is a special tool, or collapse in vice and hold with bailing wire
Other adverts from twostrokesmoke
