SlammedSunny Posted November 19, 2012 Report Share Posted November 19, 2012 I just got my KA24E swap back to my house and noticed that the harness has a few "flaws" a couple cut wires and broken connectors. The main one is that the o2 sensor has been completly bypassed the harness and ran as a seperate line straight to the ECU. mainly I want to know what color the O2 sensor wire is so i can repair it and run it properly again. Second, I am missing a lot of the metal clips that hald the connecters in place, IE. injectors, ect... Can I buy these new? or even the whole connector new and replace them as i have a few that the plastic is broken. Thanks Quote Link to comment
FiveSeventyZee Posted November 19, 2012 Report Share Posted November 19, 2012 looks like a white wires what you're after. unfortunately there are multiple white wires so you may have to unwrap the harness and trace it from the ecu pin. prob the better way to do it anyway tho incase you find a fault in the wire...there's usually a reason things are rigged like that 1 Quote Link to comment
SlammedSunny Posted November 23, 2012 Author Report Share Posted November 23, 2012 This works perfectly for me thanks, does anybody have a Ka24e subharness diagram? That would help a lot too Quote Link to comment
FiveSeventyZee Posted December 5, 2012 Report Share Posted December 5, 2012 Just saw this, I should have a wiring diagram for this if you still need it. I'll look through my books tomorrow. Quote Link to comment
Rustina 510 Posted December 5, 2012 Report Share Posted December 5, 2012 Post it please because this is a good info thread for my single cam swap in the works also Quote Link to comment
FiveSeventyZee Posted December 5, 2012 Report Share Posted December 5, 2012 will do. I'll post what I have when I get home today Quote Link to comment
Draker Posted December 5, 2012 Report Share Posted December 5, 2012 As for the metal clips, you can simply use a well cut paper clip. 1 Quote Link to comment
FiveSeventyZee Posted December 6, 2012 Report Share Posted December 6, 2012 a couple of mine have broken/gotten lost and I've been running it without them. I check my sensor connections way more often than most and nothing has come loose yet. although now I might go unbend a bunch of paper clips haha Quote Link to comment
FiveSeventyZee Posted December 6, 2012 Report Share Posted December 6, 2012 Alright here's some more info on the wiring, the wiring diagram pics can be enlarged and zoomed to make all the font legible. they should be high enough resolution that you can read eveything KA24E Engine harness diagram 510 Chassis Diagram (not sure if anyone needs this but I'm just posting all related info at this point) 240sx engine bay with locations of sensory and emissions components If you want to pull the emissions stuff off you can lose #'s 1, 2, 4, 6, & 8. You can probably pull the charcoal canister as well but I can't really help anyone on how to do that (probably just literally remove it lol) since my engine didnt come with one, then again most ppl who swap probably wont put the charcoal canister in to start with. I used this thread to pull the smog stuff, lmk if anything isnt clear http://www.ka-t.org/...pic.php?t=10789 Quote Link to comment
erichwaslike Posted December 6, 2012 Report Share Posted December 6, 2012 ok so ive got a 240 ka24e and im wondering if a hardbody ka24e ecu can be used on them and if anyone has tried, ive looked at the diagrams in all the fsm's and it seems that id need to move 1-2 pins and the only other issue is one has a full throttle swith and the other doesnt... can anyone help? Quote Link to comment
FiveSeventyZee Posted December 7, 2012 Report Share Posted December 7, 2012 something tells me you aren't gonna find anyone whose tried that. which really means the only way to find out is try it. I only have the information I posted (haven't seen the hardbody wiring diagram) but it sounds like it could work if you switch those pins. only thing is whats a full throttle switch? I'm guessing it tells the ECU when you're at full throttle but why? the ECU's using that information to control something. figure out what its controling and go from there. or find a hardbody ecu, switch the pins you know need switching and plug it in, but I'd try to figure out what the deal is with the full throttle switch. Quote Link to comment
erichwaslike Posted December 11, 2012 Report Share Posted December 11, 2012 its the one from post #9 where you posted the stanza/240sx diagram... the throttle valve switch. i think its just a auto trans thing for a lock up converter. i dont think the hardbody came auto.... Quote Link to comment
FiveSeventyZee Posted December 15, 2012 Report Share Posted December 15, 2012 I think you are correct and I'm thinking that means it should work. a 240 ecu on a truck motor may throw a code for missing that switch but the truck ecu doesn't know that the circuit exists so it should work that direction Quote Link to comment
