Hoosier77 Posted April 14, 2011 Report Share Posted April 14, 2011 In need of an engine harness diagram as well as an ecu pinout, i have the 62 ecu which is the manual tranny. I have found one ecu pinout on the net but the colors do not match mine :blink:. If someone had the engine harness diagram that would be great!!! thanks Quote Link to comment
sssr20det510 Posted April 14, 2011 Report Share Posted April 14, 2011 I think the fsm is in the how to wire a ka ca sr into anything Quote Link to comment
Hoosier77 Posted April 14, 2011 Author Report Share Posted April 14, 2011 there is no fsm for a silvia or 180sx in there, is there something else in there that would work? the pulsar has the ca18 Quote Link to comment
sssr20det510 Posted April 14, 2011 Report Share Posted April 14, 2011 What is it that u are needing it for, are u wiring it into a datsun? Quote Link to comment
Hoosier77 Posted April 14, 2011 Author Report Share Posted April 14, 2011 uhhhhh yeah :huh: i need the diagram so i can reference it with my harness to find out whats what, I obviously dont need and power steering, or ac anything. And i need to knwo what connectors are what, which wires to use with the can am, yada yada yada, does anyone have the diagram??? the ecu pinouts i find online are not color coded the same as mine. if anyone has an engine harness diagram and a pinout diagram it would help me greatly!!!!! Quote Link to comment
sssr20det510 Posted April 14, 2011 Report Share Posted April 14, 2011 All the info is in the how to thread, the fsm are listed under the 240sx for the sr, also the diagram for the box shows what color wires are the correct ones and there pin number Quote Link to comment
Hoosier77 Posted April 14, 2011 Author Report Share Posted April 14, 2011 thanks for the information but do you have something i can download so i can read JAPANESE!!!! what the heck guys, there is another file under 240sx labeled wiring but i cannot open it because its a "PCX" file wtf? :angry: Let me rephrase my question, DOES ANY MEMBER OF THIS FORUM KNOW WHERE I CAN FIND AN ALTERNATIVE (other than the japanese version in the fsm directory) WIRING DIAGRAM FOR A VEHICLE ORIGINALLY EQUIPPED WITH AN S13 SR20DET REDTOP WITH MANUAL TRANSMISSION? I would really really really really really appreciate it, THANKS Quote Link to comment
Hoosier77 Posted April 14, 2011 Author Report Share Posted April 14, 2011 yes i have that one, those colors are incorrect on the pinout, i wish it was that simple. I cannot for the life of me figure which harness this is. Quote Link to comment
sssr20det510 Posted April 14, 2011 Report Share Posted April 14, 2011 you might have a x type then, if so the #62 ecu wont work Quote Link to comment
Hoosier77 Posted April 14, 2011 Author Report Share Posted April 14, 2011 the j4 and j5 is that the compute=r number? my computer is a 62, ill check the pins though to see if the colors are correct. would there be a problem if i was using the older 180 sx harness with a newer computer? thanks Quote Link to comment
sssr20det510 Posted April 14, 2011 Report Share Posted April 14, 2011 yes you need a j4 or j5 ecu or you could re pin it for the 62 ecu good luck Quote Link to comment
Hoosier77 Posted April 14, 2011 Author Report Share Posted April 14, 2011 i think i have figured it out, the pinout i needed was the 1991 to 1993, i was holding the harness plug and reading it that way instead of looking at what pin was on the ecu corresponding with the plug as if it was plugged in. Dumb move i know, i should be all good now!!!! thanks man!! Quote Link to comment
sssr20det510 Posted April 14, 2011 Report Share Posted April 14, 2011 ok glad you figured it out Quote Link to comment
